• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    johnq
    Lost plot style manager
    229 Views, 2 Replies
    02-13-2013 06:52 PM
    Hi folks
    This morning I had a FATAL ERROR,  nothing unusual about that as this often happens when closing files.
    This time it happened when I was updateing a BoM.
    Reboot was OK. All seemed OK and all I lost was a few devices on a drawing.
    Later I came to print and discovered I have lost the "plot style manager" in the "format" ribbon menue.
    I knew this as ACE reported that there was a problem witht the printer.
    How do I get it back?  (the plot style manager)
    I have lost the .pc3 file for the printer and I can't recreate it.   ACAD reports that i am writing to and illegal file.
    I use CutePDF to create my PDF files and I have also lost the .pc3 file.
    These two .pcs files are usually in the printer menue of ACE where I select which printer I wish to print from.
    I can print previously save PDF drawings correctly.
    Hope some one can steer me in the righ direction.
    Cheers  John Quigley
    Please use plain text.
    Distinguished Contributor
    Re: Lost plot style manager
    02-22-2013 08:15 AM in reply to: johnq
    This is an interesting issue...
    Have you lost the ability to invoke the plot manager from the big "A" as well?
    (Big "A" > Print > Manage plotters)
    Can you check in the CUI to see if you still have ACAD as a partial load in your ACADE workspace.
    (Look for ACAD in the Partial Customization Files expandable tree)
    I have seen this before in an older version of the product (ACADE 2007), it would lose the partial file that allowed Regular AutoCAD commands to run. (usually on a fatal crash during startup).
    Try reloading the partial file.
    Let me know,
    James Alger
    SolidCAD
    johnq
    02-24-2013 02:17 PM in reply to: algerj
    Hi James
    Thanks againg for your time to reply to my questions.
    I have been partially stupid.   The Plot style manager is greyed out when I look for it under the Format button.
    I forgot to look for it under the file botton.
    My other problems have been solved with the reload.
    Cheers  jq
