AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Looking for this block
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello
Wich block in Electrical does this connection ?
I mean to tag SW2
Dan
Re: Looking for this block
- Highlight
- Email to a Friend
Hi Dan
I am on ACE2012 and in it WDDOT is the block for a DOT.
To find it I drew two wires which crossed and put at the junction a DOT from the icon Menue.
Double left clock on the DOT and the list comes up and WDDOT block name should be highlighted.
Hope this is what you want and helps.
As in many Elecrtrical programs it is a seriesof concentric circles. A solid dot has more bytes.
Cheers jq
- Highlight
- Email to a Friend
Hi
I have just reread your question and To answer the real question you ned to include the drawing.
Did you draw the diagram?
Cheers jq
- Highlight
- Email to a Friend
Which block do you mean....
The Capacitor (HCA1 or VCA1 or HCA1EL or VCA1EL located under Miscellaneous, Electronics)
The Switch (closest I could get is HDS11Q89 or VDS11Q89 located under Breakers/Disconnects)
The wire Junction (WDDOT as someone has already replied with)
The H or V indicate the orientation of the component. H for Horizontal and V for Vertical.
Go to the Insert component tool and look in the sections I gave for the location. Using this tool will select the correct orientation depending on the wire you insert the block into.
Note that I listed both the plain and the Electrolytic versions of the capacitor.
Regards Brad
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as Brad Coleman
- Highlight
- Email to a Friend
Hello all,
I meant to the block with the red lines and 4 circles.
Dan
- Highlight
- Email to a Friend
it is a switch of some kind and the wires can connect to other point whenever I choose to.
Dan
