• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Location of Scratch Database?
    212 Views, 1 Replies
    05-05-2010 03:32 PM
    Is there a way to change the location the scratch database is stored? I am really talking about a setting a user can do individually since it looks like this can be set in the environment file, although I have not played around with that setting.
    Thanks. Edited by: hanchris on May 5, 2010 6:31 PM
    Please use plain text.
    Product Support
    Re: Location of Scratch Database?
    10-26-2012 11:19 AM in reply to: hanchris
    I realize that this is an old thread, but I thought I'd reply so that it might be useful to others searching for this information.  Here is the method to redirect the project scratch database files in AutoCAD Electrical 2013.  For other versions, the path locations will be the same, but the names will vary slightly.
    1. Close AutoCAD Electrical.
    2. Create a new folder where you want the project scratch database files to reside.
    3. Copy the lastproj.fil file from C:\Users\<username>\AppData\Roaming\Autodesk\AutoCAD Electrical 2013\R19.0\enu\Support\User and paste it into the new folder you made in step 2. (Note that on Windows XP, the path will be C:\Documents and Settings\<username>\Application Data\Autodesk\AutoCAD Electrical 2013\R19.0\enu\Support\User.)
    4. Open the WD.env file in Notepad and edit it as shown in this screen capture:
    5. Close and save the changes to the WD.env file.
    6. Launch AutoCAD Electrical and verify that the scratch database files are now being stored in the new specified location.
    Zac Travis
    GCSO - Frontline Technical Support
