AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Lisp routine wd_import_ scratch_md b_doit
- Highlight
- Email to a Friend
- Report Inappropriate Content
I would like to import infomation from a table in the scratch mdb which is not on the list of table choices when you execute AEIMPORTDB (from the menu or icon). I found the wd_import_scratch_mdb_doit routine in the documentation and wrote the following code to test it:
;;; **** This code assumes the current drawing is the first drawing in the active project ****
;;; **** and reads data only from the table BLOCK_ATTR ****
(defun c:db_upd ( / fnam tbl_lst hdl idx)
(setq tbl_lst (list "BLOCK_ATTR"))
(setq idx "1")
(setq fnam (c:wd_mdb_get_proj_scratch_dbnam nil)) ; "nil"=get current proj mdb file name
(setq hdl (wd_mdb_GetHandle 1)) ; get next handle, MDB format
(if hdl
(progn
(if (wd_mdb_Open hdl fnam) ; open current project's mdb file
(progn
; import new data from scratch db fnam = scratch db name, idx=dwg index within prj,
; tbl_lst= a list of tables from which to import data
(c:wd_import_scratch_mdb_doit fnam idx tbl_lst 0)
(wd_mdb_Close hdl)
(setq hdl nil)
This code did not error but reports no mismatches found even though I have changed the scratch db. Is there another step to force the new entries in the scratch db into my drawing?
