• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    BillHamlin1901
    License Check out for Acad Electrical
    217 Views, 5 Replies
    11-27-2012 11:30 AM
    We checked out a license for our Acad Electrical and disconnected from the network. We shutdown, restarted and it appeared to work OK.
    When our designer got to the site, hours away, the program seemd to forget the project/path settings. He could not insert the electrical symbols, and it appeared to be pointed at the wrong set of symbols. We got help from our reseller, but it would be nice to avoid next time.
    Is there another thing we need to do besides checking out a license? Do we need separate PROFILEs set up or some such?
    Please use plain text.
    Active Contributor
    btackes
    Re: License Check out for Acad Electrical
    11-28-2012 07:13 AM in reply to: BillHamlin1901
    Checking out a license only insures you are able to use the software when not connected to the license server.  If your projects are setup to use network libraries and catalogs it will still look for them at that location.  An easy way to handle this is to copy your network files locally and write a batch file to map the copied folders to match your network setup.  Then when you are disconnected from the network you can run the batch file before starting AutoCAD Electrical and it'll work the same as when connected to the network.
    *Expert Elite*
    11-28-2012 07:22 AM in reply to: btackes
    You can also set up your network folders to work offline. This will keep a cached copy of all the network folders on your local computer and will treat them as if you are connected to the network.
    I do this al lthe time.
    Bob Hanrahan
    Ace User since 1998
    Active Member
    BillHamlin1901
    11-28-2012 08:35 AM in reply to: BillHamlin1901
    Thank both of you for the replies.
    Bob,
    Is what you are describing a Windows function, or an AutoCAD function please?
    Bill
    *Expert Elite*
    11-28-2012 09:05 AM in reply to: BillHamlin1901
    Bill,
    It is a Windows function.
    Here is a writeup about it.
    http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/csc_working_offline.m...
    Bob Hanrahan
    Ace User since 1998
    Active Member
    BillHamlin1901
    12-04-2012 03:57 PM in reply to: testsubject
    I'm wondering if that might improve performance just slightly too. Would there be less traffic over the network.
