• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Layers don't lock on Layer Isolate AutoCAD Electrical 2011
    189 Views, 2 Replies
    09-07-2012 02:24 PM
    When I use Layer Isolate to isolate a layer and then try to window around it to change layers for example, any items that are in the window, isolated or not, are selected. Is there a system variable that can be set to make Layer Isolate work as it did in previous versions of AutoCAD Electrical where only isolated layers will be selected and the other layers will be frozen or locked?
    Ken
    Please use plain text.
    Active Contributor
    Re: Layers don't lock on Layer Isolate AutoCAD Electrical 2011
    09-10-2012 06:38 AM in reply to: aeiken
    When you go into the layer isolate command, hit S for settings.  You can lock and fade the layers from there.
    09-12-2012 04:05 AM in reply to: aeiken
    Thanks! That was just the fix I needed! Ken Miller Instrumentation and Controls AEI | AFFILIATED ENGINEERS, INC. 5802 Research Park Boulevard | Madison, WI 53719 P: 608.441.6665 | F: 608.238.2614 kmiller@aeieng.com | www.aeieng.com
