• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Member
    Thorolfur
    Item catalog change
    208 Views, 1 Replies
    09-14-2010 04:07 AM
    Hello
    I made a drawing set with certain type of control relays.  Now I have information about the relays that were used in the project and the pin numbers on them are not the same as I put on the drawings.  Is it possible to change the catalog information all in one run and update the pin numbers at the same time?
    With best regards
    Thorolfur
    Please use plain text.
    Distinguished Contributor
    CAD-ICE
    Re: Item catalog change
    03-20-2012 07:09 AM in reply to: Thorolfur
    Hi, use Component update from Catalog placed under the project tab.
    Hope this helps.
    Regards, Gary
