AutoCAD Electrical
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Invisible Attributes
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
101 Views, 3 Replies
01-24-2004 08:09 AM
I am wondering how to make some attributes of a block invisible. I want to make the descriptions and cross reference attribute on relay contacts invisible.
I would just delete them, but there may be some time in the future where i would want that information on the print.
Please let me know if you have any ideas,
Keith
Keith
Re: Invisible Attributes
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-25-2004 07:45 AM in reply to:
krollenhagen
Keith,
Tthere are a couple of ways to do this. You can set the attributes to be invisible when you create the block. But I would insert the block with the attributes visible, then use ACADE's "HIDE" command from the toolbar (move, list, edit..... attribute) to hide any attributes I don't want to be seen. Then if you ever want to see them, you can simply "unhide" the attributes. The drawback is that this is totally manual for each block as it is inserted.
Martin
Martin
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-26-2004 07:47 AM in reply to:
krollenhagen
Martin-
Thank you for your response. That will do for now.
Does anyone know of a way to make this automatic with the name of the block instead of having to do each time that I insert the block onto a drawing?
Thank you,
Keith
Thank you,
Keith
*Jared Bunch \(Autodesk, Inc\)
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-27-2004 11:07 AM in reply to:
krollenhagen
Keith
If you want an attribute to be invisible by default, just open the block
drawing, and change the property on that particular attribute to be
INVISIBLE. Then, if you want to see it, all you have to do is use the
UNHIDE command which is the counterpart to the feature that Martin was
telling you about.
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"krollenhagen" wrote in message
news:3237683.1075132074604.JavaMail.jive@jiveforum 1.autodesk.com...
> Martin-
drawing?
> Thank you,
> Keith
