• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Insertion of Saved Circuit and Hidden Wire Numbers
    49 Views, 1 Replies
    03-17-2004 09:41 AM
    Is that any way for the "insert saved circuit" command to insert a circuit that has hidden wire numbers and not have the hidden wire numbers to become visible?
    It is possible to uncheck the "Update circ's TEXT layers as req'd" option, but this leaves all the other attributes as the saved circuit layers instead of the layers specified in the drawing configuration.
    Hyun Kim
    Powell Electrical Mfg. Co.
    Please use plain text.
    *Nate Holt \(Autodesk\)
    Re: Insertion of Saved Circuit and Hidden Wire Numbers
    03-27-2004 09:31 PM in reply to: hkim
    Hyun, You are exactly right. "Fixed" wire numbers saved on the "hidden wire number layer" are not maintained on that layer when the circuit is later re-inserted. I could not figure out a good workaround. This is now logged in the queue (defect #559066). Don't be surprised if you see this working better in the next release. Thanks! Nate.
