Message 1 of 9
12:29 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to modify the standard AutoCAD destination ellipse (HA5D1_REF) so that the insertion point is on the right side. Every attempt to do so includes setting the insertion point and the wire connection at the same point (center right). However, each attempt results in the following error message: Insertion Point...not in line with wire connections". After attempting to edit the block, it inserts correctly into the drawing, however, it fails to save.
