• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Accepted Solution
    Insert Component Configuration
    201 Views, 2 Replies
    11-20-2012 07:30 AM
    Is it possible to configure the insert component menu .dat file so when you choose a component, it automatically inserts the symbol in a specific place rather than prompt the user where to insert it?
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    Re: Insert Component Configuration
    11-21-2012 12:59 AM in reply to: dbrblg
    Yes,
    In the Iconmenu wizard, add a COMMAND instead of a COMPONENT.
    For the command string, use something like
    (c:wd_insym2 "VMO13" (list 0.0 0.0) nil nil)
    This will insert a vertical motor at 0,0, with no dialog box after insertion.
    Have a look at the API help for more options for the wd_insym2 command...
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
    11-21-2012 01:18 AM in reply to: rhesusminus
    Thanks very much, your'e a star :smileyvery-happy:
    Works a treat.
