• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    New Member
    IEC symbols?
    81 Views, 1 Replies
    07-12-2004 10:48 AM
    I have been trying to use the IEC standard symbols from the libraries, but certain symbols are can't be located when I try and insert them...specifically a 3 pole disconnect...anyone have any ideas?
    Please use plain text.
    *Nate Holt
    Re: IEC symbols?
    07-12-2004 11:10 AM in reply to: gtperez
    This may or may not fix the problem... make sure that you have the "IEC" icon menu selected in addition to the IEC2 or IEC4 symbol library. To check the menu, select the "Symbol LIB" button on your project dialog (lower left-hand corner). On the next dialog make sure that the "Icon menu file:" edit box shows iec_menu.dat (for AcadE 2004) or ace_iec_menu.dat (for AcadE 2005). "gtperez" wrote in message news:18885441.1089654526417.JavaMail.jive@jiveforum1.autodesk.com... > I have been trying to use the IEC standard symbols from the libraries, but certain symbols are can't be located when I try and insert them...specifically a 3 pole disconnect...anyone have any ideas?
