AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: IEC Symbols Add-in
- Highlight
- Email to a Friend
Purging did not change anything. Still having the same issue
- Highlight
- Email to a Friend
Doug McAlexander
Electrical CAD Industry Specialist
Independent Consultant/Instructor/Mentor
AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
Web site: www.ECADConsultant.com
E-mail: ECADConsultant@gmail.com
Phone: (770) 841-8009
- Highlight
- Email to a Friend
The panel menu and library is the same for all. The footprints are physical representations and therefore look the same in any standard. However, the footprints are in English units, not Metric. You should go to the Panel configuration menu and set a scale factor of 25.4 if inserting the footprints into a Metric drawing environment.
Doug McAlexander
- Highlight
- Email to a Friend
First of all, BACKUP all your dwgs in the project in case of problems.
Now go to the Swap/Updat Block function.
In the Update block section, there is a way to swap all blocks to the equivelant block in a different library. Use this to update all your existing blocks at once.
Then do a full rebuild of the project before you double check that everything is correct.
Regards Brad
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as Brad Coleman
- Highlight
- Email to a Friend
Hi Bob,
Thanks for the tips, it helps to solve my problem.
Cheers,
Eric
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
The Panel menu stays the same because it is a physical representation of the part which does not change.
Ace User since 1998
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Glad I could help. Please mark this as resolved.
Doug McAlexander
