• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Accepted Solution
    Hyd lib look-up not finding hyd-iso125
    156 Views, 4 Replies
    06-19-2006 08:55 AM
    When I pick an item from the icon menu for insert, it gives the error of file not found, and list all the folders it looks into. But none of these is the Hyd-iso125 folder. So how do I add the search path to include this folder?
    Eric
    Please use plain text.
    *Pat Murnen \(Autodesk\)
    Re: Hyd lib look-up not finding hyd-iso125
    06-19-2006 09:48 AM in reply to: MTE Controls
    Eric, if you are using AcadE 2007 you right click on the project name and
    pick Properties. Under the Project Settings tab you add this path to the
    Schematic Libraries. If you are using Acade 2006 then you right click on the
    project name and select Symbol Libraries and add it under the Schematic
    libraries section.
    You can add any paths under these. They will be searched in the order
    listed.
    Pat Murnen
    wrote in message news:5210885@discussion.autodesk.com...
    folder?
    Eric
    Valued Contributor
    06-19-2006 09:53 AM in reply to: MTE Controls
    That did it Thank you very much. For I was in a holding pattern. Thanks Again
    Hey why is everything inserted in vertical position and offering the rotation opption.
    Eric Message was edited by: MTE Controls
    06-19-2006 11:53 AM in reply to: MTE Controls
    If I understand your question - the default orientation of the symbol is
    based on the drawing ladder property. If the default ladder orientation is
    Vertical then the default symbol orientation is Horizontal. It does check
    for underlying wires but not until after you select the location. You can
    check the box on the Icon menu to first try the other orientation and it
    will be remembered but only for that acad session.
    Pat Murnen
    wrote in message news:5210975@discussion.autodesk.com...
    Again
    rotation opption.
    Eric
    Valued Contributor
    06-20-2006 04:10 AM in reply to: MTE Controls
    Thanks, I found out by going to the new demo and studied it for a bit.
    Eric
