AutoCAD Electrical
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Horizontal and vertical source/des tination arrows
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello Everyone,
In my project, on some of the pages, vertical source arrow and its attributes are very tiny. I checked everything but I couldn't find the solution.
All the drawings have the same properties.
Also, I attached the picture showing the situation.
Thanx in advance
Tolga
Re: Horizontal and vertical source/des tination arrows
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can't see the picture, but as far as I understand you need this:
Change attribute size
Use this tool to change attribute text size quickly when components or wire numbers were already inserted onto your drawings.
Ribbon: Schematic tab
Edit Components panel
Modify Attributes drop-down
Change Attribute Size.
Toolbar: Edit Attributes
Menu: Components
Attributes
Command entry: AEATTSIZEPick | Selects the new attribute size by picking a similar text or attribute. |
Size | Specifies the attribute size value. |
Width | Specifies the attribute width value. |
Apply | Applies the new size or width values to the selected attributes. |
Single | Changes the size of the attributes as you select them. |
By name | Changes all attributes of a certain type. Select an example attribute for AutoCAD Electrical to determine the name of the attribute. All attributes of the same name are found and adjusted to your specified size. |
Type it | Specifies an attribute name for AutoCAD Electrical to match, wildcard characters are allowed. Window an area containing the attributes you want changed. All attributes that match the typed name are found and adjusted to the specified size. For example, you want to change all the description attributes on all the PLC modules on your drawing. Select "Type it," and then enter "DESC*" for the attribute name. Window the entire drawing. You can include a series of attribute names to match by separating each attribute name with a semi-colon. (Example: "DESC*;TAG*") |
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry, I attached the wrong file. Here is the correct one.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry I didn't catch sight of the size of arrow in you text... Maybe smth is wrong with it in library, I can't say surely.
But you could type Scale in command line and make it bigger.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Although, your pictures do not clearly show the issue, I have seen this before.
The last time I saw the issue, running a normal Aduit (Big "A" > Drawing utilities> aduit) on the page with the issue cleared it up.
I also made sure the library was correct (I suggest using JIC125 as a base test for this) The JIC1 library should have all text at .1 but its not the case. In fact I think I have seen sizes from 0.085 up to 0.115.
If the library is the issue you could fix the library by using the "Modify Symbol Library" command.
I hope this helps,
James Alger
SolidCAD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As you suggest, I scale IEC2 library with scale factor of 5. But nothing changes. I am also sending a screenshot of my library settings.
Was it the correct library that I edited?
Regards
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi there,
Could it be that the symbol ACADE inserts isn´t in the IEC2 Library and therefore gets it from another library?
You see if ACADE does not find the symbol in the first library defined in the list it continues down the list and searches other libraries. Try double clicking on the small arrow and take note of the block name. See if this block exists in the IEC2 library.....if not then ACADE is picking the symbol from another library most certainly with another scale factor.
I hope this helps you in the right direction.
Regards, Gary
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, in that case there are 2 more things I would like you to check.
1. The drawing scale for the dwg ( Big "A" > Drawing Utilities > Units)
Make sure the insertion scale is the same as the library, so mm since you are using IEC2
2. Make sure the Drawing setting's scale is set properly (right click on the drawing > Drawing Properties )
in the last tab "Drawing format" find the scale set it to "inch scaled to mm" (sometimes full mm doesn't work properly.., and for IEC2, inches will not work at all)
If both of those are fine then it could be that the drawings were edited and saved in inches instead of mm.
Let me know,
James Alger
SolidCAD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
James,
2nd solution worked. Thanx for the solution.
Regards
Tolga
