AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: HOW TO PUT PANEL BOM ON PANEL LAYOUT
- Highlight
- Email to a Friend
I need the table to come in so that it will fit flush in the top right hand corner of the page. Im not sure that i would be able to accomplish this without having a defined width and starting point.
where do you place your BOM?
- Highlight
- Email to a Friend
Top Left since that is the default insertion point for AutoCAD tables.
Ace User since 1998
- Highlight
- Email to a Friend
top right corner, i just place it in the center of the page and move it to the corner afterwards, with OSNAP on.
- Highlight
- Email to a Friend
Is putting the BOM in the top left of the drawing a commonly used method?
- Highlight
- Email to a Friend
WOW, That works perfect
Im still intrigued on how i cannot get it to automatically hold the table width that I set. There has to be a way to do what Im trying to get it to do and do it automatically, but just placing it somewhere close and using osnap works amazing
thanks everyone for your input
- Highlight
- Email to a Friend
Here's an .avi of what i mean. the overall width of the BOM will change from project to project, but it'll be pretty close to the same (unless you have really long part numbers or descriptions you use from time to time). i always know what general space i have for layouts
- Highlight
- Email to a Friend
I don't know if it is the common method, but like I said, that is the default for AutoCAD (not just ACE) so it is easier for me to just insert it there.
A couple less steps...
Ace User since 1998
- Highlight
- Email to a Friend
Thank you for the .avi video iomaxx
Trying to make the table have a defined width using the .set file was driving me insane, im still not done looking into it. If i can get the table to come in with a defined width and flush in the top right hand corner ill let you know
Once again thanks to everyone for your input
- Highlight
- Email to a Friend
I am wondering if you are trying to set the widths
1. Run Report Format Setup command
2. Pick the report
3. Pick Put on Drawing
4, set your table options, including Define Widths
5. Pick OK on the Table Generation Setup dialog
6. Back on the Report Format Setup dialog pick Sav
7. Run the report
8. On the very first dialog pick Format and browse
9. On the Report Generator dialog pick Put on Draw
Pat Murnen
Principal Content Developer
Information Modeling and Platform Products Group
Autodesk, Inc.
- Highlight
- Email to a Friend
Thank you Pat
I created a new format file and that fixed it
Problem solved
