• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Re: HOW TO PUT PANEL BOM ON PANEL LAYOUT
    01-31-2013 11:31 AM in reply to: iomaxx
    I need the table to come in so that it will fit flush in the top right hand corner of the page. Im not sure that i would be able to accomplish this without having a defined width and starting point.
    where do you place your BOM?
    Please use plain text.
    *Expert Elite*
    01-31-2013 11:34 AM in reply to: Vulcan1970
    Top Left since that is the default insertion point for AutoCAD tables.
    Bob Hanrahan
    Ace User since 1998
    Distinguished Contributor
    01-31-2013 11:36 AM in reply to: Vulcan1970
    top right corner, i just place it in the center of the page and move it to the corner afterwards, with OSNAP on.
    Active Contributor
    01-31-2013 11:37 AM in reply to: testsubject
    Is putting the BOM in the top left of the drawing a commonly used method?
    Active Contributor
    01-31-2013 11:42 AM in reply to: iomaxx
    WOW, That works perfect
    Im still intrigued on how i cannot get it to automatically hold the table width that I set. There has to be a way to do what Im trying to get it to do and do it automatically, but just placing it somewhere close and using osnap works amazing
    thanks everyone for your input
    01-31-2013 11:43 AM in reply to: iomaxx
    Here's an .avi of what i mean. the overall width of the BOM will change from project to project, but it'll be pretty close to the same (unless you have really long part numbers or descriptions you use from time to time). i always know what general space i have for layouts
    *Expert Elite*
    01-31-2013 11:44 AM in reply to: Vulcan1970
    I don't know if it is the common method, but like I said, that is the default for AutoCAD (not just ACE) so it is easier for me to just insert it there.
    A couple less steps...
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    01-31-2013 11:50 AM in reply to: iomaxx
    Thank you for the .avi video iomaxx
    Trying to make the table have a defined width using the .set file was driving me insane, im still not done looking into it. If i can get the table to come in with a defined width and flush in the top right hand corner ill let you know
    Once again thanks to everyone for your input
    Employee
    01-31-2013 11:51 AM in reply to: Vulcan1970
    I am wondering if you are trying to set the widths while placing the report rather than using the separate Report Format Setup command.
    1. Run Report Format Setup command
    2. Pick the report
    3. Pick Put on Drawing
    4, set your table options, including Define Widths and the actual widths
    5. Pick OK on the Table Generation Setup dialog
    6. Back on the Report Format Setup dialog pick Save Format File and give it a name.
    7. Run the report
    8. On the very first dialog pick Format and browse to the file created in the Report Format Setup.
    9. On the Report Generator dialog pick Put on Drawing. The settings should be preset on the Table Generation Setup dialog.
    Pat Murnen
    Principal Content Developer
    Information Modeling and Platform Products Group
    Autodesk, Inc.
    Active Contributor
    01-31-2013 11:57 AM in reply to: murnenp
    Thank you Pat
    I created a new format file and that fixed it
    Problem solved
