• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    allaboutmotion
    HELP!!! Components and Ladders insert incorrectly
    64 Views, 2 Replies
    11-28-2011 06:13 AM
    I have a huge problem.  I can not get my ladders to go to the insert point correctly.  I am using the standard ladder but as I click on a point to start the ladder it automatically jumps up and to the left.  It is not really far off, but as you know, any little bit off can cause huge problems in an existing drawing or new.  Please help me to figure this out.  I have looked into the properties of the drawing, but can't find a setting that fixes it.
    I am stuck until this gets answered!  Please respond quickly with anything that might help.
    Thanks, D
    Please use plain text.
    Employee
    Re: HELP!!! Components and Ladders insert incorrectly
    11-28-2011 07:07 PM in reply to: allaboutmotion
    Hi allaboutmotion,
    I have tried to reproduce this issue, but I am not seeing the same behavior as you have reported.
    What's your operating system and AutoCAD Electrical version use ?
    Do you turn on the Snap mode?
    Try this workaround: go to Ribbon > Schematic tab > Edit Components panel > hit Move Circuit button > select the ladder > Enter > move it to the correct position (turn on the Object Snap).
    Kevin Li
    Valued Contributor
    11-29-2011 12:10 PM in reply to: allaboutmotion
    Sounds like your snap is on and set to something fairly large like 0.500.
    Scott
    Scott G. Sawdy
    scott.sawdy@bluecoyotecad.com
