• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Global attribute switch
    45 Views, 1 Replies
    04-13-2004 11:47 AM
    Is there a way to turn on/off attributes globally?
    I am adding locations to components on an existing schematic to easy creating panel layouts, and the "loc" attribute seems to be turned on for all components on the drawing.
    I don't need the location to show on the electrical schematic.
    Please use plain text.
    *Jared Bunch \(Autodesk, Inc\)
    Re: Global attribute switch
    04-13-2004 12:33 PM in reply to: fdna49
    You should be able to just do this by turning off the LOC layer. The LOC code attribute should be getting automatically placed on this layer, therefore turning it off should "hide" all of the LOC attributes in that drawing. Hope this helps!! -- Regards, Jared Bunch Technical Support Specialist Autodesk, Inc "fdna49" wrote in message news:21563245.1081882065033.JavaMail.jive@jiveforum2.autodesk.com... > Is there a way to turn on/off attributes globally? > I am adding locations to components on an existing schematic to easy creating panel layouts, and the "loc" attribute seems to be turned on for all components on the drawing. > I don't need the location to show on the electrical schematic.
