• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    Generating an automated table of contents
    212 Views, 3 Replies
    11-28-2012 11:50 AM
    Is there a way to generate an automated table of contents on a sheet to where the table of contents takes the description, sheet number, and section off of each sheet in the project and lists each in a row of the table?
    Please use plain text.
    Member
    palahnukb
    Re: Generating an automated table of contents
    11-28-2012 01:01 PM in reply to: gjarus
    What you're looking for would be Drawing List Report.  In the Project Manager Pane right click on the project that needs the table of contents and select Drawling List Report.  From there you can specify what drawings to go into the report, the format of it and what fields should be included.  Here's the Autodesk Wiki Page: Drawing List Report.
    Member
    11-28-2012 01:24 PM in reply to: palahnukb
    That is a much easier way of doing it than what I was doing. I was manually updating it. The only difference is that it isn't as ascetically pleasing.
    Distinguished Mentor
    11-28-2012 02:12 PM in reply to: gjarus
    To get the looks that you want, go to Format, Table Style. Select the ACE table style and modify it to suit how you want the table to look.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
