AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Footprint database location
- Highlight
- Email to a Friend
- Report Inappropriate Content
How do I determine which Footprint lookup database is active. I have been adding components to the database both in my office and at home. We have a network install so I assume the database is being shared. But when I go home is must default to some other offline database. Some of the components that I edited in the database at home are no longer available in my office. Is there any way to keep them syncronized?
I have also seen today that a couple of components that I added to the database were getting the footprints from my local folder. I am not sure why?
Re: Footprint database location
- Highlight
- Email to a Friend
So, if I understand you correctly...
How do I determine which Footprint lookup database is active - Go to Options in AutoCAD Electrical, In Options> Files tab (First tab) and write the new path to it. But don't forget to remove (better make archive) base from
- Windows XP:C:\Documents and Settings\{username}\My Documents\Acade {version}\AeData\Catalogs\
- Windows 7: C:\Users\{username}\Documents\Acade {version}\AeData\Catalogs\
And from other folders:
AutoCAD Electrical search sequence
1st choice -- <project>_footprint_lookup.mdb in the subdirectory of the project
2nd choice -- footprint_lookup.mdb in the subdirectory of the project
3rd choice -- footprint_lookup.mdb in user subdirectory
4th choice -- footprint_lookup.mdb in panel subdirectory
5th choice -- AutoCAD search paths (you change this)
Maybe the only solution is to copy the base for homework and then return it to a shared folder.
- Highlight
- Email to a Friend
In the project manager, right-click the active project, and select Settings...
In the dialog that pops up, scroll down to Panel footprint lookup mdb file and you'll find the active database.
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
