• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    mewescott
    Footprint database location
    159 Views, 2 Replies
    08-28-2012 12:05 PM
    How do I determine which Footprint lookup database is active.  I have been adding components to the database both in my office and at home.  We have a network install so I assume the database is being shared.  But when I go home is must default to some other offline database.  Some of the components that I edited in the database at home are no longer available in my office.  Is there any way to keep them syncronized?
    I have also seen today that a couple of components that I added to the database were getting the footprints from my local folder.  I am not sure why?
    Please use plain text.
    Valued Contributor
    Nata_ly
    Re: Footprint database location
    12-06-2012 07:17 AM in reply to: mewescott
    So, if I understand you correctly...
    How do I determine which Footprint lookup database is active - Go to Options in AutoCAD Electrical, In Options> Files tab (First tab)  and write the new path to it. But don't forget to remove (better make archive) base from
    • Windows XP:C:\Documents and Settings\{username}\My Documents\Acade {version}\AeData\Catalogs\
    • Windows 7: C:\Users\{username}\Documents\Acade {version}\AeData\Catalogs\
    And from other folders:
    AutoCAD Electrical search sequence
    1st choice -- <project>_footprint_lookup.mdb in the subdirectory of the project
    2nd choice -- footprint_lookup.mdb in the subdirectory of the project
    3rd choice -- footprint_lookup.mdb in user subdirectory
    4th choice -- footprint_lookup.mdb in panel subdirectory
    5th choice -- AutoCAD search paths (you change this)
    Maybe the only solution is to copy the base for homework and then return it to a shared folder.
    Distinguished Mentor
    rhesusminus
    12-06-2012 11:50 AM in reply to: mewescott
    In the project manager, right-click the active project, and select Settings...
    In the dialog that pops up, scroll down to Panel footprint lookup mdb file and you'll find the active database.
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
