• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Footprint TERMXX attribute upper/lower case
    218 Views, 3 Replies
    09-27-2012 02:20 AM
    I have a footprint symbol of a connector with terminals that are identified with letters that are both upper and lower case. For example there is a pin "M" and a pin "m". When doing the wire annotation ACADE does not seem to be able to tell the difference. It puts the wire number against pin M where it should be on the m pin.
    How can I solve this problem? Is there a setting somewhere?
    Please use plain text.
    Re: Footprint TERMXX attribute upper/lower case
    10-01-2012 01:18 AM in reply to: John
    Am I the only person who uses footprints with wire info?
    This is ACADE's most important feature!
    Active Member
    tonymynd
    04-23-2013 02:01 PM in reply to: John
    Nope. There is a world wide strugle in the industry for a reliable and affordable Artifical Itelligence Software for Automatic Wire Numbering, Routing, Sequencing, etc.
    Valued Contributor
    04-24-2013 09:41 AM in reply to: John
    Can you post an image of the connector block? I would like to see the pin attributes.
    Ricardo
