• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Member
    Font Style
    181 Views, 7 Replies
    01-11-2013 06:57 PM
    Is there a way to make all the text the same font. I have wire labels, wire color and gauge labels and multi line text. They are all different style of fonts. Just wondering if there is a way to make them all the same or how to change them individual to be the same.
    Please use plain text.
    Valued Contributor
    Re: Font Style
    01-13-2013 05:26 PM in reply to: mtennie
    Did you try the project wide utilities to change the fonts style?
    Goto the Project tab, Proj Tools panel, Utilites.
    Change the Attributes size and style.
    Hope this is what you looking for.
    Active Contributor
    kc8akw
    Re: Font Style
    01-14-2013 08:11 AM in reply to: mtennie
    We did use the Utilities.  At this point, we are setting the text styles of each, individual attribute.
    Active Member
    Re: Font Style
    01-14-2013 10:39 AM in reply to: mtennie
    I have but it doens't seem to be changing the font of the text.
    Valued Contributor
    Re: Font Style
    01-15-2013 01:43 PM in reply to: mtennie
    I had to change the text style in ALL of the blocks that came with ACADE.  A long and tedious process.  I did use the record function to select all objects, then I picked by group, MTEXT, TEXT and ATTDEF and changed the text style enmass for each block.  Thought about doing a routine that could be set to run through the entire library, but I did not have the time to go back and relearn LISP.
    Scott
    Scott G. Sawdy
    scott.sawdy@bluecoyotecad.com
    Valued Contributor
    Re: Font Style
    01-15-2013 06:00 PM in reply to: sonny3g
    I came across this old topic, maybe it can help with the script file that you need for the font style. "Change the font of the Installati​on code through out project." http://forums.autodesk.com/t5/AutoCAD-Electrical/Change-the-font-of-the-Installation-code-through-ou...
    Distinguished Contributor
    s.wile
    Re: Font Style
    01-16-2013 09:58 PM in reply to: sonny3g
    sonny3g I hate to tell you this now...
    Hidden under the Symbol Builder is a tool called Modify Symbol Library.
    This utility allows you to change font heights, styles, and if needed run a script on EVERY block in a folder.
    Sorry to tell you this after you modified every symbol manually.
    Stan Wile
    http://myacade.blogspot.com/
    IMAGINiT Technologies
    Valued Contributor
    Re: Font Style
    01-17-2013 05:45 AM in reply to: s.wile
    That is okay, I had to make adjustments to the placement of most of the text and to some of the insertion points as well.
    Scott
    Scott G. Sawdy
