AutoCAD Electrical
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way to make all the text the same font. I have wire labels, wire color and gauge labels and multi line text. They are all different style of fonts. Just wondering if there is a way to make them all the same or how to change them individual to be the same.
Re: Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did you try the project wide utilities to change the fonts style?
Goto the Project tab, Proj Tools panel, Utilites.
Change the Attributes size and style.
Hope this is what you looking for.
Re: Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We did use the Utilities. At this point, we are setting the text styles of each, individual attribute.
Re: Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have but it doens't seem to be changing the font of the text.
Re: Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had to change the text style in ALL of the blocks that came with ACADE. A long and tedious process. I did use the record function to select all objects, then I picked by group, MTEXT, TEXT and ATTDEF and changed the text style enmass for each block. Thought about doing a routine that could be set to run through the entire library, but I did not have the time to go back and relearn LISP.
Scott
scott.sawdy@bluecoyotecad.com
Re: Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
sonny3g I hate to tell you this now...
Hidden under the Symbol Builder is a tool called Modify Symbol Library.
This utility allows you to change font heights, styles, and if needed run a script on EVERY block in a folder.
Sorry to tell you this after you modified every symbol manually.
http://myacade.blogspot.com/
IMAGINiT Technologies
Re: Font Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is okay, I had to make adjustments to the placement of most of the text and to some of the insertion points as well.
Scott
