• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    Flexible Terminal Block Size
    59 Views, 2 Replies
    02-05-2004 12:34 PM
    Is there a way to create a terminal block that will, when inserted, ask for number of terminals, spacing, and numbering sequence. I would like to place like I do Ladder rungs and/or fence Insert.
    Please use plain text.
    Valued Contributor
    Re: Flexible Terminal Block Size
    02-11-2004 12:25 PM in reply to: Sjef
    Yes... you need to use the panel builder function of AutoCAD Electrical, You will need to assign catalog part numbers in your electrical drawings and a footprint in the footprint lookup table. You than can generate all your terminal block assignments automatically.
    Dave
    New Member
    02-12-2004 02:10 PM in reply to: Sjef
    Thanks, I will look into the panel build part of the program, I will probably have more questions later.
    thanks
