• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    Fix attributes at the same position
    190 Views, 1 Replies
    12-20-2012 07:24 AM
    When I revert a block, the attributes reverse too. Is there any way to make those attributes be fixed at the same position independently if the block will be reverse or not?
    Marina.
    Please use plain text.
    Active Contributor
    kghew1
    Re: Fix attributes at the same position
    12-20-2012 08:23 AM in reply to: Marina.M
    Hi Marina
    Have you tried checking 'Graphics only' in the Reverse / Flip Component dialogue ?
    Note too that this function likes components with only a couple of terminals, but gets confused when there are lots of terminals, or opposed terminals that are not exactly in line with each other on opposite sides of the symbol.
    I have also seen a quirk with some symbols where if you reverse them, then decide that you liked it better the first way, and try to re-reverse them back again - they simply vanish.
    Hope this helps
    Keith H
