• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    CAD-ICE
    File "0.dwg" is inaccessible
    293 Views, 8 Replies
    06-03-2012 04:58 AM
    Hi there,
    I have some issues with my external references between parent relay symbols and child symbols. For some reason the external reference does not show up at the parent symbol. I have tried everything but without luck. I get a message from the project database service that file "0.dwg" is inaccessible but I have no idea what that´s referring to?? (see attached image)
    I´m using ACADE2012 and I have already deleted the scratchdatabase and did a full rebuild of the database but I´m still having this problem.
    Any thought´s appreciated.
    Regards, Gary
    Please use plain text.
    *Expert Elite*
    Re: File "0.dwg" is inaccessible
    06-04-2012 08:09 AM in reply to: CAD-ICE
    Post a couple of drawings that illustrate this issue.  There is no known bug related to this in the software to my knowledge.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    CAD-ICE
    06-04-2012 04:16 PM in reply to: dougmcalexander
    Hello Dough and thank´s for offering your help on this one.
    I found out that somehow the parent/child relationship was lost and that seemed to cause the problem. By deleting both symbols and inserting new instead I got thing´s back to normal. Do you know of an easier workaround in order to reestablish the relationsship again?
    Thank´s again.
    Regards, Gary
    *Expert Elite*
    06-04-2012 05:31 PM in reply to: CAD-ICE
    Did you try a Refresh/Rebuild?  Or better still, exit Electrical and delete the projectname.mdb file located in the User subfolder.  Ex.  C:\Users\Doug McAlexander\AppData\Roaming\Autodesk\AutoCAD Electrical 2013\R19.0\enu\Support\User
    Doug McAlexander
    CAD-ICE
    06-04-2012 06:05 PM in reply to: dougmcalexander
    yes I tried first the full rebuild and then deleted the projectname.mdb file but that didnt solve the issue??
    So I went the hard way deleting both symbols and reinserted them again. Strangely if I just deleted the parent coil and inserted a new parent, the new parent did show simultaniously a reference to a the child but seemed to have missed out that the child is a form C contact but did only show the child´s NO contact in the XREF ?? Strange behaviour to say the least!
    Thank´s again for your support.
    Regards, Gary
    *Expert Elite*
    06-04-2012 07:29 PM in reply to: CAD-ICE
    Did you run the Cross-reference Update?
    Doug McAlexander
    CAD-ICE
    06-05-2012 02:20 AM in reply to: dougmcalexander
    Yes I did several times but the relay´s in question never showed up with the cross reference to the child contacts. If I inserted a new relay and hooked it up with a child contact, it worked perfectly.
    Regards, Gary
    Distinguished Mentor
    rhesusminus
    10-11-2012 04:53 AM in reply to: CAD-ICE
    If you stumble into this later on, try this also;
    Use the "Hide/Unhide Cross-referencing"...
    THL
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
    Member
    05-15-2013 01:10 AM in reply to: CAD-ICE
    HAVE THE SAME PROBLEM (XREF TO 0.DWG ) TRIED ALL LISTED SALUTION
    NOTHING HELP
