• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Distinguished Contributor
    Justin2012
    File path
    138 Views, 2 Replies
    12-07-2012 10:41 AM
    I keep gettin a message in regards to the below file path(attachment).When I follow the path I can't locate it ; I don't know if there is another location it can be on.
    C:\Users\rfobi\AppData\Roaming\Autodesk\AutoCAD Electrical 2011\R18.1\enu\Support\IMAGES
    In symbol builder, I want to add a new symbol name from a secondary catalog and not from the default catalag. How is the possible? I don't want to tamper with the default catalog but the secondary.
    Please let me know. Thanks
    Please use plain text.
    cbenner
    Re: File path
    12-07-2012 11:23 AM in reply to: Justin2012
    Not sure what exactly you are doing, have you created the symbol already and now you are trying to insert it?  The image you posted shows that AcadE is looking for a .dwg file... like a block.  Most likely the location of that block needs to be added to your file search path.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Justin2012
    Re: File path
    12-10-2012 05:17 AM in reply to: cbenner
    This is the debut for creating a new block. Under select symbol/object, the "type" column have some family names. My question is if it is possible to add another family through through another path like the secondary catalog.
    Thats correct - the location has to be added but when I follow the link to add the loaction I can't find it. I know this is strange...do you know how I can search and add this file path?
    Please let m eknow. Thanks
