• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Failed to start Terminal Editor
    124 Views, 5 Replies
    08-29-2011 07:48 AM
    Suddenly I can't start the Terminal Strip Editor anymore.
    I get a dialog with "Updating" and the green process, but then it hangs
    If I kill the process ACEPMCOMSERVER9 in the Task Manager then it continuous but then the "Terminal strip Selection" is empty.
    I did try the following to solve the problem but unitl now without success.
    1. Reinstall AE from the Control Panel --> Software
    2. Switched projects
    2. Deleted the *.MDB files in the user folder
    AE 2012 -- 64 Bits
    Available hotfixes are applied
    Windows 7  Ultimate
    Please use plain text.
    Employee
    Re: Failed to start Terminal Editor
    08-29-2011 06:58 PM in reply to: Gaituuth
    Hi Gaituuth,
    Thanks for the report !
    And can you check if processes ACEPMCOMSERVER9.exe and ACEPMDB32.exe *32 are running in Task Manager ? Both of them should be running when Autocad Electrical launches under 64 bit OS.
    You described "Terminal strip selection" is empty, do you mean the dialog can be lauched but no data in it or there is some error message shown in command line? For example, "Problem opening database file or doesn't exist".
    Kevin Li
    SQA Engineer
    Autodesk, Inc.
    08-30-2011 12:14 AM in reply to: KevinLi-Autodesk
    Hi Kevin Li,
    Yes, both ACEPMCOMSERVER9.exe and ACEPMDB32.exe *32 are running in the taskmanager.
    When ending the ACEPMCOMSERVER9 process in the task manager, I get the dialog box for the Terminal Editor where I normally can select the terminal strips.
    I have to kill the ACEPMCOMSERVER9 process todo something with AE, otherwise I get the dialogbox with the progressbar but then nothing is happening anymore also the CPU load for AE is 0.
    On the commandprompt of AutoCAD I did saw onetime a message that the database is not available.
    Als Edit Component is causing the same issue.
    Employee
    08-30-2011 08:02 PM in reply to: Gaituuth
    Hi Gaituuth,
    Thanks for your reply !
    ACEPMCOMSERVER9 is a background update process according to project database. We don't suggest to kill it in Task Manager in order to do something in Autocad Electrical, it will cause some unnormal issues.
    The dialog box with the progress bar indicates Autocad Electrical is doing update due to some operations, for example, parent-child sync, project wide utilities update......
    In your previous post, you observe AutoCAD Electrical hangs during update, i suppose your CPU or memory is used up, or there is memory leak during updating on your project.
    And now since not only Terminal Editor but also Edit component has the problem, I suggest to Repair your Autocad electrical from Control Panel.
    Hope it can resolve your problem.
    One more question is if you run terminal strip editor for ALL projects (including default demo projects), all of them hangs, right ?
    Kevin Li
    08-31-2011 11:27 PM in reply to: KevinLi-Autodesk
    I know not to kill the AcePmcomserver9 process but that's the only way todo something with AutoCAD.
    In my first post I already did a repair but that didn't help.
    Also switching to other projects doesn't help. The same issue is occuring.
    I solved the problem  in the following way, uninstalled all Autodesk products and then reinstall it starting with Plant 3D. This costed me almost a day.(The installation and uninstall of AE is very very sloooooowwwww)
    The cause of the problem is the AutoCAD Plant 3D. During the installation of this software it screws up the AutoCAD Electrical installation.
    On my system I can reproduce the problem, if you install Plant 3D after AE then AE is not functioning anymore (Repair, reinstall doesn't work).
    Again to get it working you have to uninstall all autodesk software.
    Then start with Plant 3d, after that you can install Autocad Electrical.
    I think autodesk has to communicate internally with the developers of AE and Plant 3D to solve the issue.
    Employee
    08-31-2011 11:49 PM in reply to: Gaituuth
    Hi Gaituuth,
    Appreciate your feedback here. Many issues can be resolved via thoroughly uninstall & reinstall, while i think it is the last way that we suggest our customer does this because it will cost much time.
    If you select all the libraries and manufactures to install, then the time is a bit long. also the install performance is related with the hardware configuration (i.e. CPU, Memory......)
    From your comments Autocad Electrical functions are affected by Autocad Plant 3D if installed Autocad Electrical firstly, i don't have experience on this item but we will take care of this notice, reproduce it and then let development team to take a look it.
    Thanks for support and report !
    Kevin Li
