• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Member
    tahir.mavric
    European Standards
    738 Views, 6 Replies
    11-16-2011 03:24 AM
    Hi all,
    I started to use AutoCAD Electrical 2012. But i can't find European Standards. I have read to another discussions where saying that IEC is also European Standard but the elements (symbols) are not the same as what I need.
    In AutoCAD ECSCAD 2012 elements (symbols) are the same as what I need. AutoCAD ECSCAD 2012 used also IEC Symbol Library.
    How can i get this standard in AutoCAD Electrical 2012?
    example: Fuse_Switches
    In AutoCAD ECSCAD 2012  -  Fuse Switches
    In AutoCAD Electrical 2012   -  Fuse Switches
    Thanks in advance,
    Tahir
    Please use plain text.
    New Member
    e.bekker
    Re: European Standards
    11-16-2011 06:35 AM in reply to: tahir.mavric
    Hi Tahir,
    It all depends on project or drawing settings and takes a lot typing to answer it here.
    My advise is to use ACAD help:
    Just type: "Switch JIC and IEC standards"
    Ed
    Valued Contributor
    11-16-2011 07:30 AM in reply to: tahir.mavric
    According to my documentation on the 60617 IEC standard, the Autocad Electrical representation is the correct one. About automatically converting your ECSCAD symbols to Autocad Electrical symbols: have no idea on how to do that.
    Jos
    Distinguished Mentor
    11-16-2011 02:26 PM in reply to: Josdc
    The Australian standard (based on the IEC) has the ESCAD block as a THERMAL OVERLOAD contact and not a Fuse switch.
    The ACADE symbol is what we use for a FUSE SWITCH.
    Try doing a Google search for the IEC standards to get an idea of what the appropriate standards are.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    11-24-2011 03:48 AM in reply to: tahir.mavric
    ECSCAD is incorrect in accordance with IEC60617. The symbols you depict from ECSCAD is a thermal contact and not a fuse switch. You can download a copy of the IEC60617 standards from the IEC store but they are expensive. A previous reply suggested typing into Google and this can often give you the correct symbol but be careful.
    Active Contributor
    12-06-2011 08:54 AM in reply to: tahir.mavric
    I believe the upper symbol is not a fuse but a circuit breaker with a thermal trip.
    12-06-2011 07:28 PM in reply to: brstilson
    The upper symbol is definitely a contact with a thermal operation. A breaker has a cross where the contact comes down....
    Regards Brad
    as Brad Coleman
