• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    mamapizzo
    Error: malformed string on input
    909 Views, 3 Replies
    03-16-2011 09:31 AM
    When trying to input any elec. Item I get this error:
    Reading C:\Documents and Settings\victoria.smithpizzo\Application
    Data\Autodesk\AutoCAD Electrical 2011\R18.1\enu\Support\ace_jic_menu.dat
    what am I doing wrong?
    Please use plain text.
    Employee
    Re: Error: malformed string on input
    03-16-2011 10:20 PM in reply to: mamapizzo
    I suppose there is some problem in your ace_jic_menu.dat file, can you attach this file here for further investigation ?
    Kevin Li
    Member
    mamapizzo
    03-17-2011 06:12 AM in reply to: KevinLi-Autodesk
    Here is the ace_jic_menu.dat file. i hope this helps.
    ; 22-Jan-10 t_kalio; Added 1ph and 3ph power source icons
    ; 22-Sep-09 t_kudam; Symbol builder modified to use new command '_.aesymbuilder'
    ; 29-Oct-08 t_gackt; One line menu - Changed string "Square/Round with terminal number" to "Square/Round terminal" and added second transformer
    ; 21-Oct-08 t_gackt; corrections in "One line" menu (new submenu)
    ; 14-Oct-08 t_gackt; changed icon file name "shc01pj" to "shc01jp_1" in submenu M101 and changed "PJ" to "Jack/Plug"
    ; 03-Oct-08 t_gackt; added new menu "One line component"
    ; 15-Nov-07 t_kudam - renamed files OL symbols to HOL2, HOL21, HOL22
    ; 17-Oct-07 t_kudam - changes made due to rename (H/V)OL11.dwg - (H/V)OL1.dwg
    ; 7-Aug-07 t_gackt - corrected spelling of word "Distribution" in **M45
    ; 14-Nov-06 Kulas inserted format information for old insert menu
    ; 05-Oct-06 Kulas Rearranged for modern icon menu
    ; 11-Dec-05 NEHolt added parametric twisted-pair symbol
    ; 06-Nov-05 NEHolt separate off-delay timer "instantaneous" contact symbols
    ; 23-Oct-05 NEHolt simplified M48
    ; 21-Oct-05 Mani added sub menu page M48 for Splice symbols
    ; 05-Oct-05 NEHolt added parametric connector build calls - 2 places
    ; 25-June-04 MJ - Changed string PLc-Direct to Automation Direct
    ; 17-May-04 PMM - corrected spelling of word "Circuit"
    ; 04-May-04 PMM - corrected one more instance of Receptacles
    ; 28-Apr-04 NEHolt - corrected spelling of word "Receptacles"
    ; 08-APR-04 JDZ - Modofoed the Title Line Removing Main Menu For DSS
    ; 29-Mar-04 JDZ - modified the Title Lines for localization
    ; 09-Jan-04 JDZ Replaced Abbreviations with full word; ready for globalization
    ; 11-Aug-03 NEHolt minor change to Latch Relay submenu page, now use normal CR contacts
    ;    to tie into latch parent coil.
    ; 06-Aug-03 NEHolt removed the NO and NC versions of HSV1. Just use HSV1 and set
    ;    the RATING1 value to NO or NC if desired.
    ; 01-Jul-03 NEHolt tick mark adds to icons that pop up submenu page required some icons
    ;    to be duplicated without the tick marks.
    ; 10-Jun-03 NEHolt split Timers into to icon pages; split Relays/Latches into two pages
    ; 10-Jun-03 AWHolt flipped PLC-Direct to DT text-only menu
    ; 06-Jun-03 PMMurnen reworked in-line wire label calls
    ; 02-Jun-03 AWHolt changed PLC full-unit menus to type "DT"
    ; 03-Jul-02 NEHolt changed "ins dumb inline wire labels" call - three places.
    ;   Minor change to Black Box Builder call under "Generic Boxes"
    ; 03-May-01 NEHolt added "$C=wd_repeat " call to each of the dumb in-line
    ;   wire label markers so that cmd repeats during insertion
    ; 22-Jul-00 NEHolt added "In line wire num copy" symbols to menu M32
    ; 21-Jun-00 NEHolt moved "Shields" from opening menu down to MISC menu
    ; 11-Jun-00 NEHolt added M45 Pwr Dist Blocks and revised M14 to pick it
    ; 03-Jun-00 NEHolt added M43,M44 and revised M21,M22 for additions
    ;   to connector pin symbol menus
    ; 29-May-00 PMMurnen added M41,M42 for new shield/cable markers
    ; 22-Feb-00 NEHolt added "Dumb, extra marker" in CABLE submenu page
    ; 18-Feb-00 NEHolt added "repeat" option for inserting wire "DOT" symbol
    ;   in the "M0" submenu page
    ; 16-Dec-99 PMMurnen eliminated "S_LD" slide lib references (2 places)
    ; 02-Aug-99 NEHolt added 1-PH motor symbol to M15
    ; 15-Jul-99 NEHolt added *M40 reference in MISC submenu in place of
    ;   call to Black Box Builder. Also added *M40 reference in Ref-Only
    ;   wire arrows submenu.
    ; 23-Jun-99 NEHolt added in "PLC" units menu pages M33-M40
    **M0
    D0
    JIC: Schematic Symbols
    Push Buttons|s2(s_pb)|$S=M3
    Selector Switches|s2(s_ss)|$S=M6
    Fuses/ Circuit Breakers/ Transformers|s2(s_cb_fu)|$S=M16
    Relays/ Contacts|s2(s_cr)|$S=M1
    Timers|s2(s_td)|$S=M2
    Motor Control|s2(s_mcc)|$S=M15
    Pilot Lights|s2(s_lt)|$S=M4
    PLC I/O|s2(s_io)|$S=M27
    Terminals/ Connectors|s2(s_trm_cn)|$S=M14
    Limit Switches|s2(s_zs)|$S=M8
    Pressure/ Temperature Switches|s2(s_ps_ts)|$S=M9
    Flow/ Level Switches|s2(s_fs_ls)|$S=M13
    Miscellaneous Switches|s2(s_msc_sw)|$S=M10
    Solenoids|s2(s_sv)|$S=M24
    Instrumentation|s2(s_inst)|$S=M25
    Miscellaneous|s2(s_msc)|$S=M18
    DOT|s1(shdot)|$C=wd_repeat WDDOT
    One-Line Components|s2(s_oneline)|$S=M100
    **M1
    D3W
    JIC: Relays and Contacts
    Relay Coil|s1(SHCR1)|HCR1
    Relay NO Contact|s1(SHCR21)|HCR21
    Relay NC Contact|s1(SHCR22)|HCR22
    Standard Coil with Pins|s1(SHCR1T)|HCR1T
    Relay NO with Pins|s1(SHCR21T)|HCR21T
    Relay NC with Pins|s1(SHCR22T)|HCR22T
    Latching Relay Coils|s2(s_cr_latch)|$S=M46
    **M2
    D4W
    JIC: Time Delay Relays
    ON Delay Coil|s2(shtD1N)|HTD1N
    ON Delay Coil with Pins|s2(shtD1NT)|HTD1NT
    ON Delay Starter|s2(shtD1NM)|HTD1NM
    ON Delay NO - TC|s2(shtD21N)|HTD21N
    ON Delay NC - TO|s2(shtD22N)|HTD22N
    ON Delay NO - TC with Pins|s2(shtD21NT)|HTD21NT
    ON Delay NC - TO with Pins|s2(shtD22NT)|HTD22NT
    Instantaneous NO|s2(shtD21I)|HTD21I
    Instantaneous NC|s2(shtD22I)|HTD22I
    Instantaneous NO with Pins|s2(shtD21IT)|HTD21IT
    Instantaneous NC with Pins|s2(shtD22IT)|HTD22IT
    OFF Delay Timers|s2(s_td_off)|$S=M47
    **M3
    D5W
    JIC: Push Buttons
    Push Button NO|s2(shpB11)|HPB11
    Push Button NC|s2(shpB12)|HPB12
    Mushroom Head NO|s2(shpB11M)|HPB11M
    Mushroom Head NC|s2(shpB12M)|HPB12M
    Illuminated Push Button NO|s2(shpb11L)|HPB11L
    Illuminated Push Button NC|s2(shpb12L)|HPB12L
    Illuminated Mushroom Head NO|s2(shpb11ML)|HPB11ML
    Illuminated Mushroom Head NC|s2(shpb12ML)|HPB12ML
    2nd+ NO Contact|s2(shpB21)|HPB21
    2nd+ NC Contact|s2(shpB22)|HPB22
    2nd+ Red Light|s2(shpb2R)|HPB2R
    2nd+ Green Light|s2(shpb2G)|HPB2G
    2nd+ Amber Light|s2(shpb2A)|HPB2A
    2nd+ Yellow Light|s2(shpb2Y)|HPB2Y
    2nd+ Blue Light|s2(shpb2B)|HPB2B
    2nd+ White Light|s2(shpb2W)|HPB2W
    2nd+ Clear Light|s2(shpb2C)|HPB2C
    **M4
    D5W
    JIC: Pilot Lights
    Red Standard|s2(shlt1R)|HLT1R
    Green Standard|s2(shlt1G)|HLT1G
    Amber Standard|s2(shlt1A)|HLT1A
    Yellow Standard|s2(shlt1Y)|HLT1Y
    Blue Standard|s2(shlt1B)|HLT1B
    White Standard|s2(shlt1W)|HLT1W
    Clear Standard|s2(shlt1C)|HLT1C
    Red Press To Test|s2(shlt1RP)|HLT1RP
    Green Press To Test|s2(shlt1GP)|HLT1GP
    Amber Press To Test|s2(shlt1AP)|HLT1AP
    Yellow Press To Test|s2(shlt1YP)|HLT1YP
    Blue Press To Test|s2(shlt1BP)|HLT1BP
    White Press To Test|s2(shlt1WP)|HLT1WP
    Clear Press To Test|s2(shlt1CP)|HLT1CP
    Master Test|s2(s_lt_m)|$S=M5
    Neon|s2(s_lt_n)|$S=M23
    **M5
    D3W
    JIC: Master Test Pilot Lights
    Red Master Test|s2(shlt1RM)|HLT1RM
    Green Master Test|s2(shlt1GM)|HLT1GM
    Amber Master Test|s2(shlt1AM)|HLT1AM
    Yellow Master Test|s2(shlt1YM)|HLT1YM
    Blue Master Test|s2(shlt1BM)|HLT1BM
    White Master Test|s2(shlt1WM)|HLT1WM
    Clear Master Test|s2(shlt1CM)|HLT1CM
    **M6
    D6W
    JIC: Selector Switches
    2 Position Maintain, NO|s2(shss112)|HSS112
    2 Position Maintain, NC|s2(shss122)|HSS122
    2 Position NO Return From Left|s2(shss112L)|HSS112L
    2 Position NC Return From Left|s2(shss122L)|HSS122L
    2 Position NO Return From Right|s2(shss112r)|HSS112R
    2 Position NC Return From Right|s2(shss122r)|HSS122R
    3 Position NO|s2(shss113)|HSS113
    3 Position NC|s2(shss123)|HSS123
    3 Position NO Return From Left|s2(shss113L)|HSS113L
    3 Position NC Return From Left|s2(shss123L)|HSS123L
    3 Position NO Return From Right|s2(shss113r)|HSS113R
    3 Position NC Return From Right|s2(shss123r)|HSS123R
    3 Position NO Return From Both|s2(shss113b)|HSS113B
    3 Position NC Return From Both|s2(shss123b)|HSS123B
    4 Position NO|s2(shss114)|HSS114
    4 Position NC|s2(shss124)|HSS124
    6 Position NO|s2(shss116)|HSS116
    6 Position NC|s2(shss126)|HSS126
    8 Position NO|s2(shss118)|HSS118
    8 Position NC|s2(shss128)|HSS128
    2nd+ NO Contact|s2(shss21)|HSS21
    2nd+ NC Contact|s2(shss22)|HSS22
    Illuminated Selector Switches|s2(S-SSI)|$S=M7
    **M7
    D6W
    JIC: Illuminated Selector Switches
    2 Position NO|s2(shss112)|HSS112I
    2 Position NC|s2(shss122)|HSS122I
    2 Position NO Return From Left|s2(shss112L)|HSS112Li
    2 Position NC Return From Left|s2(shss122L)|HSS122Li
    2 Position NO Return From Right|s2(shss112r)|HSS112Ri
    2 Position NC Return From Right|s2(shss122r)|HSS122Ri
    3 Position NO|s2(shss113)|HSS113i
    3 Position NC|s2(shss123)|HSS123i
    3 Position NO Return From Left|s2(shss113L)|HSS113Li
    3 Position NC Return From Left|s2(shss123L)|HSS123Li
    3 Position NO Return From Right|s2(shss113r)|HSS113Ri
    3 Position NC Return From Right|s2(shss123r)|HSS123Ri
    3 Position NO Return From Both|s2(shss113b)|HSS113Bi
    3 Position NC Return From Both|s2(shss123b)|HSS123Bi
    Red Light|s2(shss2R)|HSS2R
    Green Light|s2(shss2G)|HSS2G
    Amber Light|s2(shss2A)|HSS2A
    Yellow Light|s2(shss2Y)|HSS2Y
    Blue Light|s2(shss2B)|HSS2B
    White Light|s2(shss2W)|HSS2W
    Clear Light|s2(shss2C)|HSS2C
    **M8
    D3W
    JIC: Limit Switches
    Limit Switch, NO|s2(shls11)|HLS11
    Limit Switch, NC|s2(shls12)|HLS12
    Limit Switch NO Held Closed|s2(shls11h)|HLS11H
    Limit Switch NC Held Open|s2(shls12h)|HLS12H
    2nd+ NO Contact|s2(shls21)|HLS21
    2nd+ NC Contact|s2(shls22)|HLS22
    2nd+ NO Contact Held Closed|s2(shls21h)|HLS21H
    2nd+ NC Contact Held Open|s2(shls22h)|HLS22H
    **M9
    D3W
    JIC: Pressure and Temperature Switches
    Pressure Switch, NO|s2(shps11)|HPS11
    Pressure Switch, NC|s2(shps12)|HPS12
    Temperature Switch, NO|s2(shts11)|HTS11
    Temperature Switch, NC|s2(shts12)|HTS12
    2nd+ Pressure NO Contact|s2(shps21)|HPS21
    2nd+ Pressure NC Contact|s2(shps22)|HPS22
    2nd+ Temperature NO Contact|s2(shts21)|HTS21
    2nd+ Temperature NC Contact|s2(shts22)|HTS22
    **M10
    D6W
    JIC: Other Switch Types
    Proximity Switch NO|s2(shpx11)|HPX11
    Proximity Switch NC|s2(shpx12)|HPX12
    2nd+ Proximity NO Contact|s2(shpx21)|HPX21
    2nd+ Proximity NC Contact|s2(shpx22)|HPX22
    Foot Switch NO|s1(shft11)|HFT11
    Foot Switch NC|s1(shft12)|HFT12
    2nd+ Foot NO Contact|s1(shft21)|HFT21
    2nd+ Foot NC Contact|s1(shft22)|HFT22
    Toggle Switch NO|s2(shtg11)|HTG11
    Toggle Switch NC|s2(shtg12)|HTG12
    2nd+ Toggle NO Contact|s2(shtg21)|HTG21
    2nd+ Toggle NC Contact|s2(shtg22)|HTG22
    Pull cord Switch NO|s2(shpc11)|HPC11
    Pull cord Switch NC|s2(shpc12)|HPC12
    2nd+ Pull Cord NO Contact|s2(shpc21)|HPC21
    2nd+ Pull Cord NC Contact|s2(shpc22)|HPC22
    A-Plug NO|s2(shlt11)|HPG11
    A-Plug NC|s2(shlt12)|HPG12
    2nd+ A-Plug NO Contact|s2(shlt21)|HPG21
    2nd+ A-Plug NC Contact|s2(shlt22)|HPG22
    Photo Eye Switch NO|s2(shpe11)|HPE11
    Photo Eye Switch NC|s2(shpe12)|HPE12
    SPDT Switches|s1(tg_more)|$S=M31
    **M13
    D3W
    JIC: Flow and Level Switches
    Flow Switch NO|s1(shfs11)|HFS11
    Flow Switch NC|s1(shfs12)|HFS12
    Level Switch NO|s1(shfL11)|HFL11
    Level Switch NC|s1(shfL12)|HFL12
    2nd+ Flow NO Contact|s1(shfs21)|HFS21
    2nd+ Flow NC Contact|s1(shfs22)|HFS22
    2nd+ Level NO Contact|s1(shFL21)|HFL21
    2nd+ Level NC Contact|s1(shFL22)|HFL22
    **M14
    D6W
    JIC: Terminals and Connectors
    Square|s2(sht0_01)|HT0_01
    Square with Wire Number|s2(sht0w01)|HT0W01
    Square with Terminal Number|s2(sht0001)|HT0001
    Square with Wire Number Change|s2(sht1001)|HT1001
    Round|s2(sht0_02)|HT0_02
    Round with Wire Number|s2(sht0w02)|HT0W02
    Round with Terminal Number|s2(sht0002)|HT0002
    Round with Wire Number Change|s2(sht1002)|HT1002
    Hexagon|s2(sht0_03)|HT0_03
    Hexagon with Wire Number|s2(sht0w03)|HT0W03
    Hexagon with Terminal Number|s2(sht0003)|HT0003
    Hexagon with Wire Number Change|s2(sht1003)|HT1003
    Diamond|s2(sht0_04)|HT0_04
    Diamond with Wire Number|s2(sht0w04)|HT0W04
    Diamond with Terminal Number|s2(sht0004)|HT0004
    Diamond with Wire Number Change|s2(sht1004)|HT1004
    Triangle|s2(sht0_05)|HT0_05
    Triangle with Wire Number|s2(sht0w05)|HT0W05
    Triangle with Terminal Number|s2(sht0005)|HT0005
    Triangle with Wire Number Change|s2(sht1005)|HT1005
    In-line Wire Labels|s1(dumb_red)|$S=M32
    Power Distribution Blocks|s2(pdb)|$S=M45
    Connectors - No Wirenumber Changes|s2(s_cn_nch)|$S=M22
    Connectors - Wirenumber Changes|s2(s_cn_chg)|$S=M21
    **M15
    D6W
    JIC: Motor Control
    3 Phase Starter Contacts NO|s1(shmt213)|$C=wd_3unit HMS21
    3 Phase Starter Contacts NC|s1(shmt223)|$C=wd_3unit HMS22
    3 Phase Starter Contacts with Overload|s1(shmt213o)|$C=wd_3unit HMS21OL
    3 Phase Overloads|s1(shol13)|$C=wd_3unit HOL1
    Motor Starter Coil|s1(SHmt1)|HmS1
    Motor Starter Coil with Pins|s1(SHmt1T)|HmS1T
    Overload|s1(shol1)|HOL1
    3 Phase Motor|s1(SHMO1)|HMO13
    2nd+ Starter Contact NO|s1(SHmt21)|HmS21
    2nd+ Starter Contact NO with Pins|s1(SHmt21T)|HmS21T
    2nd+ Overload|s1(shol2)|HOL2
    1 Phase Motor|s1(shmo12)|HMO12
    2nd+ Starter Contact NC|s1(SHmt22)|HmS22
    2nd+ Starter Contact NC with Pins|s1(SHmt22T)|HmS22T
    2nd+ Overload Contact NO|s1(SHOL21I)|HOL21
    KVAR Capacitor|s1(SHCA11)|HCA11
    3 Phase KVAR|s1(SHCA13)|HCA113
    2nd+ Overload Contact NC|s1(SHOL22I)|HOL22
    2nd+ KVAR Capacitor|s1(SHCA21)|HCA21
    Ground|s1(shgnd2)|HGND2
    Fuses/ Circuit Breakers|s2(s_cbfu)|$S=M16
    Breakers/ Disconnects|s2(s_cb_ds)|$S=M17
    **M16
    D5W
    JIC: Fuses, Circuit Breakers and Transformers
    ;Circuit Breaker 1 Pole|s1(shcb1)|HCB1
    Fuse (Tag)|s1(shfu1)|HFU1
    Fuse|s1(shfu0)|HFU0
    ;2nd+ Circuit Breaker 1 Pole|s1(shcb2)|HCB2
    2nd+ Fuse|s1(shfu2)|HFU2
    Fuse Switch (Right)|s1(shds1fr)|HDS11FR
    Fuse Switch (Left)|s1(shds1fL)|HDS11FL
    3 Pole Fuse with Tags|s1(shfu3p)|$C=wd_3unit HFU1
    2nd+ Fuse Switch(Right)|s1(shds2fr)|HDS21FR
    2nd+ Fuse Switch (Left)|s1(shds2fL)|HDS21FL
    Transformer|s2(shxf1)|HXF1
    Transformer Dual|s2(shxf1d)|HXF1D
    Current Transformer|s2(shxf1ct)|HXF1CT
    Potential Transformer|s2(shxf1pt)|HXF1PT
    Circuit Breakers/ Disconnects|s2(s_cb_ds)|$S=M17
    **M17
    D6W
    JIC: Disconnecting Means
    Thermal Circuit Breaker|s1(shcb1th)|HCB11TH
    Motor Circuit Protector|s1(shcb1m)|HCB11M
    Motor Circuit Protector with Fuse|s1(shcb1mcl)|HCB11ML
    2nd+ Thermal Circuit Breaker|s1(shcb2th)|HCB21TH
    2nd+ Motor Circuit Protector|s1(shcb2m)|HCB21M
    2nd+ Motor Circuit Protector with Fuse|s1(shcb2mcl)|HCB21ML
    3 Pole Circuit Breaker|s1(shcb13)|$C=wd_3unit HCB1
    3 Pole Thermal Circuit Breaker|s1(shcb1th3)|$C=wd_3unit HCB11TH
    3 Pole Motor Circuit Protector|s1(shcb1m3)|$C=wd_3unit HCB11M
    3 Pole Motor Circuit Protector with Fuse|s1(shcb1ml3)|$C=wd_3unit HCB11ML
    Circuit Breaker Auxilary Contact NO|s1(shcb21it)|HCB21IT
    Disconnect Switch|s1(shds1)|HDS11
    Fused Disconnect Switch|s1(shds1f)|HDS11F
    Disconnect Switch Auxilary Contact NO|s1(shds21it)|HDS21IT
    2nd+ Disconnect Switch|s1(shds2)|HDS21
    2nd+ Fused Disconnect Switch|s1(shds2f)|HDS21F
    3 Pole Disconnect|s1(shds13)|$C=wd_3unit HDS11
    3 Pole Fused Disconnect|s1(shds1F3)|$C=wd_3unit HDS11F
    **M18
    D6W
    JIC: Miscellaneous
    Bell|s1(shan1b)|HAN1B
    Buzzer|s1(shan1z)|HAN1Z
    Horn|s1(shan1h)|HAN1H
    Electronics|s2(s_tronic)|$S=M28
    Earth/Ground|s1(shgnd1)|HGND1
    Battery|s1(shba1)|HBA1
    Battery (Flipped)|s1(shba1r)|HBA1R
    Suppressor (tag)|s2(shsu1)|HSU1
    Suppressor|s2(shsu0)|HSU0
    Enclosure Light|s1(s_ltenc)|HLT1ENC
    Cable Markers|s1(shw01)|$S=M30
    Receptacles|s1(s_cnrdup)|$S=M29
    Shields (Non Intelligent)|s2(s_shld1)|$S=M41
    Splice symbols|s2(splice_horizontal)|$S=M48
    User Circuits|s2(s_usr_ck)|$S=M19
    Generic Boxes|s1(s_box)|$S=M20
    Stand-Alone Cross-Reference Symbols|s2(sa_refs)|$S=M40
    Wire Arrows Reference only|s1(s_a_ref)|$S=M26
    Power Source 1 Phase|s1(PS1_1PH)|VPW1_1PH
    Power Source 3 Phase|s1(PS1_3PH)|VPW1_3PH
    **M19
    D6W
    JIC: Saved User Circuits
    User Circuit 1|%WD_USER%circ1|$C=wd_ins_circ_main %WD_USER%circ1
    User Circuit 2|%WD_USER%circ2|$C=wd_ins_circ_main %WD_USER%circ2
    User Circuit 3|%WD_USER%circ3|$C=wd_ins_circ_main %WD_USER%circ3
    User Circuit 4|%WD_USER%circ4|$C=wd_ins_circ_main %WD_USER%circ4
    User Circuit 5|%WD_USER%circ5|$C=wd_ins_circ_main %WD_USER%circ5
    User Circuit 6|%WD_USER%circ6|$C=wd_ins_circ_main %WD_USER%circ6
    User Circuit 7|%WD_USER%circ7|$C=wd_ins_circ_main %WD_USER%circ7
    User Circuit 8|%WD_USER%circ8|$C=wd_ins_circ_main %WD_USER%circ8
    User Circuit 9|%WD_USER%circ9|$C=wd_ins_circ_main %WD_USER%circ9
    User Circuit 10|%WD_USER%circ10|$C=wd_ins_circ_main %WD_USER%circ10
    User Circuit 11|%WD_USER%circ11|$C=wd_ins_circ_main %WD_USER%circ11
    User Circuit 12|%WD_USER%circ12|$C=wd_ins_circ_main %WD_USER%circ12
    User Circuit 13|%WD_USER%circ13|$C=wd_ins_circ_main %WD_USER%circ13
    User Circuit 14|%WD_USER%circ14|$C=wd_ins_circ_main %WD_USER%circ14
    User Circuit 15|%WD_USER%circ15|$C=wd_ins_circ_main %WD_USER%circ15
    User Circuit 16|%WD_USER%circ16|$C=wd_ins_circ_main %WD_USER%circ16
    User Circuit 17|%WD_USER%circ17|$C=wd_ins_circ_main %WD_USER%circ17
    User Circuit 18|%WD_USER%circ18|$C=wd_ins_circ_main %WD_USER%circ18
    User Circuit 19|%WD_USER%circ19|$C=wd_ins_circ_main %WD_USER%circ19
    User Circuit 20|%WD_USER%circ20|$C=wd_ins_circ_main %WD_USER%circ20
    User Circuit 21|%WD_USER%circ21|$C=wd_ins_circ_main %WD_USER%circ21
    User Circuit 22|%WD_USER%circ22|$C=wd_ins_circ_main %WD_USER%circ22
    User Circuit 23|%WD_USER%circ23|$C=wd_ins_circ_main %WD_USER%circ23
    User Circuit 24|%WD_USER%circ24|$C=wd_ins_circ_main %WD_USER%circ24
    **M20
    D3W
    JIC: Generic Device Boxes
    4 Terminals|s1(shdv1tfl)|HDV1TFL
    3 Terminals|s1(shdv1tc)|HDV1TC
    3 Terminals|s1(shdv1tb)|HDV1TB
    2 Terminals|s1(shdv1t6)|HDV1T6
    4 Terminals|s1(shdv1tf)|HDV1TF
    3 Terminals|s1(shdv1te)|HDV1TE
    3 Terminals|s1(shdv1t7)|HDV1T7
    Symbol Builder|s1(shblkbox)|$C=_.AESYMBUILDER
    **M21
    D3W
    JIC: Connectors - Wirenumber Changes
    Plug/Jack|s2(shcn1pj)|HCN1PJ
    Jack/Plug|s2(shcn1jp)|HCN1JP
    2nd+ Plug/Jack|s2(shcn2pj)|HCN2PJ
    2nd+ Jack/Plug|s2(shcn2jp)|HCN2JP
    Spare/Single Side Only|s2(c0_1)|$S=M43
    Parametric build|s2(paraconn)|$C=wd_p2p_connector_dlg_wnum_chg
    **M22
    D3W
    JIC: Connectors - No Wirenumber Changes
    Plug/Jack|s2(shc01pj)|HC01PJ
    Jack/Plug|s2(shc01jp)|HC01JP
    Plug/Jack (Combined Tag-Pin)|s2(shc01pj1)|HC01PJ1
    Jack/Plug (Combined Tag-Pin)|s2(shc01jp1)|HC01JP1
    2nd+ Plug/Jack|s2(shc02pj)|HC02PJ
    2nd+ Jack/Plug|s2(shc02jp)|HC02JP
    2nd+ Plug/Jack (Combined Tag-Pin)|s2(shc02pj1)|HC02PJ1
    2nd+ Jack/Plug (Combined Tag-Pin)|s2(shc02jp1)|HC02JP1
    Spare/Single Side Only|s2(c0_1)|$S=M44
    Parametric build|s2(paraconn)|$C=wd_p2p_connector_dlg_wnum_nochg
    **M23
    D2W
    JIC: Neon Pilot Lights
    Red Standard|s2(shlt1Rn)|HLT1RN
    Amber Standard|s2(shlt1an)|HLT1AN
    Clear Standard|s2(shlt1Cn)|HLT1CN
    **M24
    D2W
    JIC: Solenoids
    Solenoid|s1(s_sv1)|HSV1
    Manual Reset Solenoid|s1(s_sv1m)|HSV1M
    NO Contact|s1(s_sv21)|HSV21
    NC Contact|s1(s_sv22)|HSV22
    **M25
    D5W
    JIC: Instrumentation
    Thermocouple|s1(s_tc1l)|HTC1L
    Thermocouple|s1(s_tc1r)|HTC1R
    Thermocouple with Terminal Board|s1(s_tc1ltb)|HTC1LTB
    Thermocouple with Terminal Board|s1(s_tc1rtb)|HTC1RTB
    Ball valve|s1(shbv1m)|HBV1M
    Gate valve|s1(shgv1m)|HGV1M
    Globe valve|s1(shlv1m)|HLV1M
    Volt Meter|s1(shvm1)|HVM1
    Amp Meter|s1(sham1)|HAM1
    **M26
    D5W
    JIC: Wire Arrows - Reference Only
    Generic Arrow - Left|s1(sha1x1)|HA1X1
    Generic Arrow - Up|s1(sha1x2)|HA1X2
    Generic Arrow - Right|s1(sha1x3)|HA1X3
    Generic Arrow - Down|s1(sha1x4)|HA1X4
    Arrow Tail - Left|s1(sha1x1y)|HA1X1Y
    Arrow Tail - Up|s1(sha1x2y)|HA1X2Y
    Arrow Tail - Right|s1(sha1x3y)|HA1X3Y
    Arrow Tail - Down|s1(sha1x4y)|HA1X4Y
    **M27
    D5W
    JIC: PLC I/O
    PLC I/O Modules|s2(s_wdio)|$C=PLC
    PLC I/O Fixed Units|s1(plcio_fix)|$S=M33
    * *  SINGLE I/O  * *||
    IN, 1st Point, 1 Wire|s1(plcioi1t)|PLCIOI1T
    IN, 1st Point, 2 Wires|s1(plcioi2t)|PLCIOI2T
    OUT, 1st Point, 1 Wire|s1(plcioo1t)|PLCIOO1T
    OUT, 1st Point, 2 Wires|s1(plcioo2t)|PLCIOO2T
    IN, 2nd+ Child, 1 Wire|s1(plcioi1)|PLCIOI1
    IN, 2nd+ Child, 2 Wires|s1(plcioi2)|PLCIOI2
    OUT, 2nd+ Child, 1 Wire|s1(plcioo1)|PLCIOO1
    OUT, 2nd+ Child, 2 Wires|s1(plcioo2)|PLCIOO2
    **M28
    D6W
    JIC: Electronics
    Fixed Resistor|s1(shre1)|HRE1
    Fixed Resistor (Box)|s1(shre1b)|HRE1B
    Fixed Resistor with Pins|s1(shre1t)|HRE1T
    Fixed Resistor (Box) with Pins|s1(shre1tb)|HRE1TB
    Variable Resistor|s1(shvr1tz)|HVR1TZ
    Variable Resistor|s1(shvr1tzr)|HVR1TZR
    Variable Resistor|s1(shvr1)|HVR1
    Variable Resistor|s1(shvr1r)|HVR1R
    Diode|s1(shdi1)|HDI1
    Diode|s1(shdi1R)|HDI1R
    Diode with Pins|s1(shdi1T)|HDI1T
    Diode with Pins|s1(shdi1TR)|HDI1TR
    Zener Diode|s1(shdi1z)|HDI1Z
    Zener Diode|s1(shdi1zr)|HDI1ZR
    Zener Diode with Pins|s1(shdi1tz)|HDI1TZ
    Zener Diode with Pins|s1(shdi1tzr)|HDI1TZR
    Capacitor|s1(SHCA1)|HCA1
    Capacitor with Pins|s1(SHCA1T)|HCA1T
    **M29
    D1W
    JIC: Power Receptacles
    Duplex Receptacle|s1(s_cnrdupl)|HCN1RDUP
    Single Receptacle|s1(s_cnrsgl)|HCN1RSGL
    **M30
    D3W
    JIC: Cable Markers
    Cable Marker|s1(shw01)|HW01
    2+ Child Marker|s1(shw02)|HW02
    Extra Marker|s1(shw02dum)|HT0_CABLE
    Cable Markers with Shields|s2(shw01_1)|$S=M42
    Twisted Pair|s2(tw_pair)|$C=wd_2unit HT0_TW
    Twisted Marker|s1(tw_marker)|$C=ace_twist_marker
    Multiple connected|s1(mult_cbl_m)|$C=wd_cblshld_bld 5
    Multiple connected (All 2nd+)|s1(mult_cbl_m2)|$C=wd_cblshld_bld_2 5
    **M31
    D5W
    JIC: SPDT Switches
    SPDT Maintained|s1(tg112)|HTG112
    SPDT Return From Down|s1(tg112d)|HTG112D
    SPDT Return From Up|s1(tg112u)|HTG112U
    SPDT Return From Both|s1(tg112b)|HTG112B
    2nd+ Maintained|s1(tg212)|HTG212
    2nd+ Return From Down|s1(tg212d)|HTG212D
    2nd+ Return From Up|s1(tg212u)|HTG212U
    2nd+ Return From Both|s1(tg212b)|HTG212B
    SPDT Maintained|s1(tg112r)|HTG112R
    SPDT Return From Down|s1(tg112dr)|HTG112DR
    SPDT Return From Up|s1(tg112ur)|HTG112UR
    SPDT Return From Both|s1(tg112br)|HTG112BR
    2nd+ Maintained|s1(tg212r)|HTG212R
    2nd+ Return From Down|s1(tg212dr)|HTG212DR
    2nd+ Return From Up|s1(tg212ur)|HTG212UR
    2nd+ Return From Both|s1(tg212br)|HTG212BR
    **M32
    DT
    JIC: In-Line Wire Labels
    Red|s1(WIRELABEL_red)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR001",nil,"RED")
    Black|s1(WIRELABEL_blk)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR002",nil,"BLK")
    White|s1(WIRELABEL_wht)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR003",nil,"WHT")
    Green|s1(WIRELABEL_green)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR004",nil,"GRN")
    Blue|s1(WIRELABEL_blue)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR005",nil,"BLU")
    Yellow|s1(WIRELABEL_yellow)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR006",nil,"YEL")
    Orange|s1(WIRELABEL_orange)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR007",nil,"ORG")
    Gray|s1(WIRELABEL_gray)|$C=wd_repeat HT0_LGENERIC COLOR=(c:wd_msg,"COLOR008",nil,"GRY")
    You Type|s1(WIRELABEL_type)|$C=wd_inlinlab_oem "HT0_LGENERIC"
    Wire Number Copy|s1(WIRELABEL_num)|$C=wd_repeat HT0_WGENERIC
    **M33
    D3W
    JIC: PLC Fixed Units
    AB 1761 MicroLogix (1/2" spacing)|s1(ab1761-50)|$S=M37
    AB 1761 MicroLogix (3/4" spacing)|s1(ab1761-75)|$S=M38
    AB 1761 MicroLogix (1" spacing)|s1(ab1761-1)|$S=M39
    Automation Direct DL105 (1/2" spacing)|s1(dl105-50)|$S=M34
    Automation Direct DL105 (3/4" spacing)|s1(dl105-75)|$S=M35
    Automation Direct DL105 (1" spacing)|s1(dl105-1)|$S=M36
    **M34
    DT
    JIC: Automation Direct DL105 (1/2" RUNG SPACING)
    F1-130AA 10in/8out 115AC-DC/115AC|s1(F1-130AA-50)|PLCIO50EF1-130AA
    F1-130AA 10in/8out 115AC-DC/24DC|s1(F1-130AA-50)|PLCIO50EF1-130AD
    F1-130AR 10in/8 relay out 115AC-DC|s1(F1-130AR-50)|PLCIO50EF1-130AR
    F1-130DA 10in s-s/8 out 24DC/115AC|s1(F1-130DA-50)|PLCIO50EF1-130DA
    F1-130DD 10in s-s/8 out 24DC/115AC|s1(F1-130DD-50)|PLCIO50EF1-130DD
    F1-130DR 10in s-s/8 relay out 24DC|s1(F1-130DR-50)|PLCIO50EF1-130DR
    F1-130DD-D 10in s-s/8 out 24DC/24DC|s1(F1-130DD-D-50)|PLCIO50EF1-130DD-D
    F1-130DR-D 10in s-s/8 relay out 24DC|s1(F1-130DR-D-50)|PLCIO50EF1-130DR-D
    **M35
    DT
    JIC: Automation Direct DL105 (3/4" RUNG SPACING)
    F1-130AA 10in/8out 115AC-DC/115AC|s1(F1-130AA-75)|PLCIO75EF1-130AA
    F1-130AD 10in/8out 115AC-DC/24DC|s1(F1-130AD-75)|PLCIO75EF1-130AD
    F1-130AR 10in/8 relay out 115AC-DC|s1(F1-130AR-75)|PLCIO75EF1-130AR
    F1-130DA 10in s-s/8 out 24DC/115AC|s1(F1-130DA-75)|PLCIO75EF1-130DA
    F1-130DD 10in s-s/8 out 24DC/115AC|s1(F1-130DD-75)|PLCIO75EF1-130DD
    F1-130DR 10in s-s/8 relay out 24DC|s1(F1-130DR-75)|PLCIO75EF1-130DR
    F1-130DD-D 10in s-s/8 out 24DC/24DC|s1(F1-130DD-D-75)|PLCIO75EF1-130DD-D
    F1-130DR-D 10in s-s/8 relay out 24DC|s1(F1-130DR-D-75)|PLCIO75EF1-130DR-D
    **M36
    DT
    JIC: Automation Direct DL105 (1" RUNG SPACING)
    F1-130AA 10in/8out 115AC-DC/115AC|s1(F1-130AA-1)|PLCIO100EF1-130AA
    F1-130AD 10in/8out 115AC-DC/24DC|s1(F1-130AD-1)|PLCIO100EF1-130AD
    F1-130AR 10in/8 relay out 115AC-DC|s1(F1-130AR-1)|PLCIO100EF1-130AR
    F1-130DA 10in s-s/8 out 24DC/115AC|s1(F1-130DA-1)|PLCIO100EF1-130DA
    F1-130DD 10in s-s/8 out 24DC/115AC|s1(F1-130DD-1)|PLCIO100EF1-130DD
    F1-130DR 10in s-s/8 relay out 24DC|s1(F1-130DR-1)|PLCIO100EF1-130DR
    F1-130DD-D 10in s-s/8 out 24DC/24DC|s1(F1-130DD-D-1)|PLCIO100EF1-130DD-D
    F1-130DR-D 10in s-s/8 relay out 24DC|s1(F1-130DR-D-1)|PLCIO100EF1-130DR-D
    **M37
    DT
    JIC: AB 1761 MicroLogix (1/2" RUNG SPACING)
    L16-AWA 10in/6out AC-DC/115AC-DC|s1(L16-AWA-50)|PLCIO50E1761-L16AWA
    L16-BBB 10in/6out 24DC/115AC-DC|s1(L16-BBB-50)|PLCIO50E1761-L16BBB
    L16-BWA 10in/6out 24DC/115AC-DC|s1(L16-BWA-50)|PLCIO50E1761-L16BWA
    L16-BWB 10in/6out 24DC/115AC-DC|s1(L16-BWB-50)|PLCIO50E1761-L16BWB
    L24-AWA 12in/12out AC-DC/115AC-DC|s1(L24-AWA-50)|PLCIO50E1761-L24AWA
    L24-BWA 12in/12out 24DC/115AC-DC|s1(L24-BWA-50)|PLCIO50E1761-L24BWA
    L32-AAA 20in/12out 115AC/115-230AC|s1(L32-AAA-50)|PLCIO50E1761-L32AAA
    L32-AWA 20in/12out AC-DC/115AC-DC|s1(L32-AWA-50)|PLCIO50E1761-L32AWA
    L32-BWA 20in/12out 24DC/AC-DC|s1(L32-BWA-50)|PLCIO50E1761-L32BWA
    **M38
    DT
    JIC: AB 1761 MicroLogix (3/4" RUNG SPACING)
    L16-AWA 10in/6out AC-DC/115AC-DC|s1(L16-AWA-75)|PLCIO75E1761-L16AWA
    L16-BBB 10in/6out 24DC/115AC-DC|s1(L16-BBB-75)|PLCIO75E1761-L16BBB
    L16-BWA 10in/6out 24DC/115AC-DC|s1(L16-BWA-75)|PLCIO75E1761-L16BWA
    L16-BWB 10in/6out 24DC/115AC-DC|s1(L16-BWB-75)|PLCIO75E1761-L16BWB
    L24-AWA 12in/12out AC-DC/115AC-DC|s1(L24-AWA-75)|PLCIO75E1761-L24AWA
    L24-BWA 12in/12out 24DC/115AC-DC|s1(L24-BWA-75)|PLCIO75E1761-L24BWA
    L32-AAA 20in/12out 115AC/115-230AC|s1(L32-AAA-75)|PLCIO75E1761-L32AAA
    L32-AWA 20in/12out AC-DC/115AC-DC|s1(L32-AWA-75)|PLCIO75E1761-L32AWA
    L32-BWA 20in/12out 24DC/AC-DC|s1(L32-BWA-75)|PLCIO75E1761-L32BWA
    **M39
    DT
    JIC: AB 1761 MicroLogix (1" RUNG SPACING)
    L16-AWA 10in/6out AC-DC/115AC-DC|s1(L16-AWA-1)|PLCIO100e1761-L16AWA
    L16-BBB 10in/6out 24DC/115AC-DC|s1(L16-BBB-1)|PLCIO100e1761-L16BBB
    L16-BWA 10in/6out 24DC/115AC-DC|s1(L16-BWA-1)|PLCIO100e1761-L16BWA
    L16-BWB 10in/6out 24DC/115AC-DC|s1(L16-BWB-1)|PLCIO100e1761-L16BWB
    L24-AWA 12in/12out AC-DC/115AC-DC|s1(L24-AWA-1)|PLCIO100E1761-L24AWA
    L24-BWA 12in/12out 24DC/115AC-DC|s1(L24-BWA-1)|PLCIO100E1761-L24BWA
    L32-AAA 20in/12out 115AC/115-230AC|s1(L32-AAA-1)|PLCIO100e1761-L32AAA
    L32-AWA 20in/12out AC-DC/115AC-DC|s1(L32-AWA-1)|PLCIO100e1761-L32AWA
    L32-BWA 20in/12out 24DC/AC-DC|s1(L32-BWA-1)|PLCIO100e1761-L32BWA
    **M40
    D3W
    JIC: Stand-Alone Cross-Reference Symbols
    Source Rectangle|s2(ha2s1_r)|HA2S1_REF
    Source Hexagon|s2(ha3s1_r)|HA3S1_REF
    Source Ellipse|s2(ha5s1_r)|HA5S1_REF
    Destination Rectangle|s2(ha2d1_r)|HA2D1_REF
    Destination Hexagon|s2(ha3d1_r)|HA3D1_REF
    Destination Ellipse|s2(ha5d1_r)|HA5D1_REF
    **M41
    D4W
    JIC: Shield Symbols
    Cable with Shield|s2(s_shld)|$C=wd_shld_bld 1
    Twisted Pair with Shield|s2(s_shld2)|$C=wd_shld_bld 2
    Shield|s2(s_shld3)|$C=wd_shld_bld 3
    Shield Tied Back|s2(s_shld4)|$C=wd_shld_bld 4
    **M42
    D4W
    JIC: Multiple Cable Markers
    Cable with Shield|s2(shw01_1notick)|$C=wd_cblshld_bld 1
    Twisted Pair with Shield|s2(shw01_2)|$C=wd_cblshld_bld 2
    Shield|s2(shw01_3)|$C=wd_cblshld_bld 3
    Shield Tied Back|s2(shw01_4)|$C=wd_cblshld_bld 4
    Add 2nd Shield|s1(shld_add_double)|$C=ace_shld_add_double
    Cable with Shield (all 2nd)|s2(shw02_1)|$C=wd_cblshld_bld_2 1
    Twisted Pair with Shield (all 2nd)|s2(shw02_2)|$C=wd_cblshld_bld_2 2
    Shield (All 2nd+)|s2(shw02_3)|$C=wd_cblshld_bld_2 3
    Shield Tied Back (All 2nd+)|s2(shw02_4)|$C=wd_cblshld_bld_2 4
    **M43
    D5W
    JIC: Connector Pins - Spare/Single Side
    Plug Right or up|s2(shc01p_)|HCN1P_
    Jack Left or Down|s2(shc01_j)|HCN1_J
    Plug Right or up (Combined tag/pin)|s2(shc01p_1)|HCN1P_1
    Jack Left or Down (Combined)|s2(shc01_j1)|HCN1_J1
    2nd+ Plug Right or up|s2(shc02p_)|HCN2P_
    2nd+ Jack Left or Down|s2(shc02_j)|HCN2_J
    2nd+ Plug Right or up (Combined)|s2(shc02p_1)|HCN2P_1
    2nd+ Jack Left or Down (Combined)|s2(shc02_j1)|HCN2_J1
    Jack Right or up|s2(shc01j_)|HCN1J_
    Plug Left or Down|s2(shc01_p)|HCN1_P
    Jack Right or up (Combined)|s2(shc01j_1)|HCN1J_1
    Plug Left or Down (Combined)|s2(shc01_p1)|HCN1_P1
    2nd+ Jack Right or up|s2(shc02j_)|HCN2J_
    2nd+ Plug Left or Down|s2(shc02_p)|HCN2_P
    2nd+ Jack Right or up (Combined)|s2(shc02j_1)|HCN2J_1
    2nd+ Plug Left or Down (Combined)|s2(shc02_p1)|HCN2_P1
    **M44
    D5W
    Plug Right or up|s2(shc01p_)|HC01P_
    Jack Left or Down|s2(shc01_j)|HC01_J
    Plug Right or up (Combined tag/pin)|s2(shc01p_1)|HC01P_1
    Jack Left or Down (Combined)|s2(shc01_j1)|HC01_J1
    2nd+ Plug Right or up|s2(shc02p_)|HC02P_
    2nd+ Jack Left or Down|s2(shc02_j)|HC02_J
    2nd+ Plug Right or up (Combined)|s2(shc02p_1)|HC02P_1
    2nd+ Jack Left or Down (Combined)|s2(shc02_j1)|HC02_J1
    Jack Right or up|s2(shc01j_)|HC01J_
    Plug Left or Down|s2(shc01_p)|HC01_P
    Jack Right or up (Combined)|s2(shc01j_1)|HC01J_1
    Plug Left or Down (Combined)|s2(shc01_p1)|HC01_P1
    2nd+ Jack Right or up|s2(shc02j_)|HC02J_
    2nd+ Plug Left or Down|s2(shc02_p)|HC02_P
    2nd+ Jack Right or up (Combined)|s2(shc02j_1)|HC02J_1
    2nd+ Plug Left or Down (Combined)|s2(shc02_p1)|HC02_P1
    **M45
    DT
    JIC: Power Distribution Blocks
    3 Terminal, 0.5 Spacing|s1(pdb-50)|HDB1350
    3 Terminal, 0.75 Spacing|s1(pdb-75)|HDB1375
    3 Terminal, 1.0 Spacing|s1(pdb-1)|HDB13100
    **M46
    D2W
    JIC: Latch Relay Coils
    ;mainlist
    Latch Relay Coil|s1(SHLR1)|HLR1
    Latch Relay Coil with pins|s1(SHLR1T)|HLR1T
    UnLatch Relay Coil|s1(SHLR1U)|HLR1U
    UnLatch Relay Coil with pins|s1(SHLR1UT)|HLR1UT
    **M47
    D3W
    JIC: OFF-Delay Timers
    OFF Delay Coil|s2(shtD1F)|HTD1F
    OFF Delay Coil with Pins|s2(shtD1FT)|HTD1FT
    OFF Delay Starter|s2(shtD1FM)|HTD1FM
    OFF Delay NO-TO|s2(shtD21F)|HTD21F
    OFF Delay NC-TC|s2(shtD22F)|HTD22F
    OFF Delay NO-TO with Pins|s2(shtD21FT)|HTD21FT
    OFF Delay NC-TC with Pins|s2(shtD22FT)|HTD22FT
    Instantaneous NO|s2(shtD21I)|HTD21IF
    Instantaneous NC|s2(shtD22I)|HTD22IF
    Instantaneous NO with Pins|s2(shtD21IT)|HTD21ITF
    Instantaneous NC with Pins|s2(shtD22IT)|HTD22ITF
    **M48
    D2W
    JIC: Splice Symbols
    Splice|s2(splice_horizontal)|HSP1001
    **M100
    JIC: One-Line Components
    Connector|s2(s_conn)|$S=M101
    Motor Control|s2(s_mot_con)|$S=M102
    Transformer|s2(s_transf)|$S=M103
    Terminal|s2(s_term)|$S=M104
    Cable Marker|s2(s_cmark)|$S=M105
    Bus Tap|s2(s_BusTap)|$S=M106
    Miscellaneous|s2(s_misc)|$S=M107
    **M101
    JIC: Connector
    Jack/Plug|s2(shc01jp_1)|Hc01pj_1-
    **M102
    JIC: Motor Control
    Circuit breaker|s1(shcb1)|Hcb11_1-
    Motor circuit protector|s1(shcb1m)|Hcb11m_1-
    Thermal circuit breaker|s1(shcb1th)|Hcb11th_1-
    Disconnect|s1(shds1)|Hds11_1-
    Fused disconnect|s1(shds1f)|Hds11f_1-
    Fuse|s1(shfu1)|Hfu1_1-
    Motor|s1(SHMO1)|Hmo13_1-
    Motor starter|s1(shmt21)|Hms11_1-
    Overload|s1(shol1)|Hol1_1-
    Vertical capacitor|s2(svca113)|Vca113_1-
    **M103
    JIC: Transformer
    Transformer 1|s2(shxf1_1)|Hxf1T1_1-
    Transformer 2|s2(shxf1_2)|Hxf1T2_1-
    **M104
    JIC: Terminal
    Square terminal|s2(sht0_01)|Ht0001_1-
    Round terminal|s2(sht0_02)|Ht0002_1-
    **M105
    JIC: Cable Marker
    Cable Marker|s1(shw01)|HW01_1-
    **M106
    JIC: Bus Tap
    Bus tap - main/dot|s2(svdv1bt1)|VDV1_BT_1-
    Bus tap - dual/tee|s2(svdv1btt1)|VDV1_BTT_1-
    Bus tap - dual/corner|s2(svdv1btl1)|VDV1_BTL_1-
    **M107
    JIC: Miscellaneous
    Power receptacle|s2(shc01wr)|Hc01wr_1-
    Generic load|s2(shdv11)|Hdv1_1-
    Employee
    03-20-2011 10:34 PM in reply to: mamapizzo
    I tried your ACE_JIC_MENU.dat file and not reproduce the eror when insert elec item. Try to repair your autocad electrical to check if this can fix your problem, go to uninstallation page, click Repair or Reinstall button, click Repair button.
    Kevin Li
