• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Error: bad xsubr(L) instruction (offs code): 37534 0
    67 Views, 1 Replies
    06-21-2004 07:00 PM
    I'm semi-new to AutoCad Electrical, and I just started the Tutorial that has you start off by opening the DEMO04.dwg file and insert a couple of rungs and a relay.
    When a new component is inserted on a wire, the ISERT/EDIT Component dialog is supposed to pop up, but I get this error in the command line instead:
    I'm sure that this is due to some irregularity on my system or in the configuration. Any help would be appreciated.
    Jay
    Please use plain text.
    Valued Contributor
    Re: Error: bad xsubr(L) instruction (offs code): 37534 0
    06-23-2004 09:34 AM in reply to: Jay Mackey
    This was fixed by a total OS re-installation on this system, and then ultimately getting rid of the RAID mirror on this computer, which appears to be the primary culprit. So far, the new AE installation on this system with RAID system removed seems to be working correctly.
    This was probably an OS generated error message that was being copied and shown in the AE comand line, rather than an internal AE error.
    Jay
