• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Error: bad argument value: non-negative: -1
    163 Views, 8 Replies
    01-07-2004 07:01 AM
    I'm receiving the following error 'Error: bad argument value: non-negative: -1' while running spread sheet to PLC generation with a custom PLC I created.
    Any help would be appreciated.
    Please use plain text.
    Re: Error: bad argument value: non-negative: -1
    01-07-2004 01:54 PM in reply to: ToddC
    Send me the file and i will see if i get the same results.
    01-08-2004 05:51 AM in reply to: ToddC
    What is your e-mail address?
    01-08-2004 05:55 AM in reply to: ToddC
    Who are you affiliated with?
    01-08-2004 04:33 PM in reply to: ToddC
    rstein546@excite.com
    I am affiliated with a VAR
    *Nate Holt \(Autodesk\)
    01-09-2004 06:06 AM in reply to: ToddC
    I remember seeing an error like this some time ago but don't recall the specifics. This is just a guess... check your custom PLC module and explode any polylines you've used. Then rerun. Let me know what you find.
    01-19-2004 06:09 AM in reply to: ToddC
    Did not find any poly lines to explode in drawing. Any other ideas. Thanks
    01-19-2004 01:06 PM in reply to: ToddC
    Send me the dwg, let me debug. "ToddC" wrote in message news:19241231.1074521456041.JavaMail.jive@jiveforum2.autodesk.com... > Did not find any poly lines to explode in drawing. Any other ideas. Thanks
    01-20-2004 09:52 AM in reply to: ToddC
    Problem is most likely the "PLC Address" index into the spreadsheet is marked "N/A" in the program's "Spreadsheet/Table Column" setup subdialog. If set to N/A then it seems to cause this problem. Also make sure that your single unit PLC symbol that you want to pop in is NOT a block insert. It needs to be exploded so that the attribute definitions are visible, otherwise you end up with a "nested" block. If you have to explode it to get this right, also make sure there is not a WD_M block also included on the drawing. Blow any WD_M block away and purge the drawing (turn ATTMODE to 2 and do REGEN to make this WD_M visible (at 0,0)). "ToddC" wrote in message news:32541377.1073487836447.JavaMail.jive@jiveforum1.autodesk.com... > I'm receiving the following error 'Error: bad argument value: non-negative: -1' while running spread sheet to PLC generation with a custom PLC I created. > > Any help would be appreciated.
