• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    MaxTec
    Error 2343 eval.msi don`t install
    3506 Views, 9 Replies
    05-31-2011 09:34 AM
    Hi
    I cant install eval.msi placed in VBA Enabler folder Autocad 2011. It shows error 2343
    How can I install that?
    My system Windows XP SP3
    Thanks!
    Please use plain text.
    Employee
    Re: Error 2343 eval.msi don`t install
    05-31-2011 07:37 PM in reply to: MaxTec
    Hi MaxTech,
    Are you trying to install VBA enabler for AutoCAD 2011?
    You can download it from this location:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14889082&linkID=9240617
    Starting with AutoCAD 2010, VBA is no longer part of the default AutoCAD installation and must be downloaded and installed separately.
    By the way, eval.msi normally resides in [SetupRes] folder and it is not meant to be installed.
    Anyway, you should always install the product using the Setup.exe in the root of the install media.
    Thanks.
    Min Keng
    Active Member
    MaxTec
    06-01-2011 04:14 AM in reply to: MinKeng
    Hi
    I tried, don't work.
    I tested in 3 computers, but don't install. I tried install also in Windows 7 don't work .
    Thanks.
    Employee
    06-01-2011 08:27 AM in reply to: MaxTec
    Is there any error message? Perhaps a screen shot will be useful.
    Thanks.
    Active Member
    MaxTec
    06-01-2011 09:12 AM in reply to: MinKeng
    Screenshot
    Thanks.
    Employee
    06-01-2011 06:12 PM in reply to: MaxTec
    Hi MaxTech,
    Please don't double click on eval.msi to install as mentioned earlier.
    If you are looking for VBA enabler, please download it from:
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12715668&linkID=9240618
    In this page, please download AutoCAD 2011 VBA module 32-bit (exe - 72064Kb) and execute it from there.
    Autodesk has begun the transition of VB customization from VBA to .NET technology. This transition will occur over a few years. During this time, Autodesk will provide documentation and other assistance to help our customers and developers migrate from VBA to this new automation technology. Starting with AutoCAD 2010, VBA is no longer part of the default AutoCAD installation and must be downloaded and installed separately. If you utilize VBA macros in your work environment, they will no longer work unless the VBA module is installed on your system.
    Refer to this link for more information:
    Min Keng
    Active Member
    MaxTec
    06-02-2011 04:32 AM in reply to: MinKeng
    Hi
    Thanks for your help.
    I had done this before, but does not work.
    Employee
    06-02-2011 08:28 AM in reply to: MaxTec
    May I know what exactly you are looking for?
    Min Keng
    Active Member
    MaxTec
    06-03-2011 10:26 AM in reply to: MinKeng
    I need Autocad Electrical 2011 API object model documents
    Member
    09-11-2012 08:11 PM in reply to: MaxTec
    Hello!
    I also I have the same problem but with Autodesk 3ds Max 2011.
    When installation is finalizing two windows appear: the first is called "Setup Initialization" and the second contains the following error:
    "The system can not find the file specified"
    C :/ Autodesk/Autodesk_3ds_Max_2011_English_Win_32-64bit/SetupRes/eval.msi
    I would be very grateful if someone could help me on this site.
    Greetings!
