• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Drawing Descriptions: Maximum of 3 Lines?
    122 Views, 2 Replies
    12-03-2011 07:00 PM
    With certain customers we must show their titleblock information as well as ours.  Which for the drawing description means showing the three line desciption twice.  But their are only three drawing description lines to use in the drawing properties form.
    Is there anyway to address this?  Can I give two different attributes the same name and have AE populate both of them with the same data?
    Can I indicate tags DD4, DD5 & DD6 in the WDT file and modify the WDP file with additional drawing description lines?  See example below:
    ===PLC CONTROL SYSTEM
    ===ELECTRICAL SCHEMATIC
    ===SHEET 7
    ===SHEET 7
    WC-3445-S07R1.dwg
    I hope someone understands what I'm asking.  Thanks ahead of time.
    Please use plain text.
    Distinguished Contributor
    Re: Drawing Descriptions: Maximum of 3 Lines?
    12-04-2011 06:18 AM in reply to: blackseabrew
    As long as the blocks are defined the same they will show the same results. If both your title blocks can display the information block the same but be in different locaitons then that should work.
    Distinguished Mentor
    12-04-2011 02:15 PM in reply to: blackseabrew
    Try pointing the attributes from their block to the same datapoints as your attributes use.
    for example...
    Your description line 1 = DD1
    Your description line 2 = DD2
    Your description line 3 = DD3
    Their Description Line 1 = DD1
    Their Description Line 2 = DD2
    Their Description Line 3 = DD3
    And so on for any other data they need duplicated...
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
