• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Disappearing PLC Information
    87 Views, 2 Replies
    01-07-2004 02:13 PM
    I have presently defined an Allen Bradley 1762-IF2OF2 module for a Microlgix 1200. When I insert it into the drawing, all the default info shows up as expected. When I go into the module to edit the info so I can specify a location, I lose some of the default lines. I can put them in but they keep going blank. How can I get these values to stay put? The vales in question are:
    Tag
    Line1
    Line2
    Mfg
    Cat
    Location
    Dick
    Please use plain text.
    Active Contributor
    Re: Disappearing PLC Information
    01-09-2004 09:31 AM in reply to: ddemerath
    It turned out to be a header terminal used 3 times. I replaced the last 2 bad ones, and everything turned out ok.
    *Nate Holt \(Autodesk\)
    01-12-2004 07:02 PM in reply to: ddemerath
    Dick, If you're willing to send me a sample dwg illustrating the problem below, I can take a look. Let me know. thanks, Nate. "ddemerath" wrote in message news:18229640.1073513688344.JavaMail.javamailuser@localhost... > I have presently defined an Allen Bradley 1762-IF2OF2 module for a Microlgix 1200. When I insert it into the drawing, all the default info shows up as expected. When I go into the module to edit the info so I can specify a location, I lose some of the default lines. I can put them in but they keep going blank. How can I get these values to stay put? The vales in question are: > Tag > Line1 > Line2 > Mfg > Cat > Location > > Dick
