• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Distinguished Contributor
    mthomas
    Accepted Solution
    Default Catalog?
    430 Views, 4 Replies
    12-14-2011 08:51 AM
    When we place a component from the catalog into our drawings it defaults on the AB catalog, which is also the largest. Is there any way to change this default?
    Mike
    Mike Thomas
    Please use plain text.
    Valued Contributor
    Re: Default Catalog?
    12-14-2011 12:16 PM in reply to: mthomas
    If you open the default catalog in access then open the _LISTBOX_DEF table this defines the presets for when you click look up.
    *Expert Elite*
    12-14-2011 12:20 PM in reply to: mthomas
    The choice of default vendor is set in the _LISTBOX_DEF table of the default_cat.mdb file.  The program is delivered with some defaults just so it functions.  The idea is for us to change as needed to suit our needs.  See attached screen capture.
    Note: This setting can be over-ruled by Block Name filtering, if a catalog record contains an entry in its WDBLKNAM field that pushes a select list of part numbers based upon the symbol block name.  The WDBLKNAM entry does not need to include the first letter "H" or "V" in the symbol name.  See attached screen capture.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    mthomas
    12-16-2011 05:50 AM in reply to: dougmcalexander
    This worked, not as easy as I thought it would be, but really like the flexibity it provides.
    Mike
    Mike Thomas
    Justin2012
    12-20-2012 11:11 AM in reply to: mthomas
    If I want the LISTBOX on my SECONDARY CATALOG to show all the components and not start with a particular mfg or etc how should I do it? Again, just the seconadry catalog
