AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Database problems after installati on of service pack 1 ACADE2012. ..Help!
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi all!
I did something yesterday I really regret doing which was installing the service pack 1 for autocad electrical 2012. I haven´t had any major issues with the software but decided to bring the software up to date by installing the service pack. Since the install I have constant problems that seem to relate to problems with the database. I have deleted the scratch database in my project and that helps in the beginning but after one update/retag things wont retag??
I´m running Windows XP 32 bit if that information is of any help.
Looking forward to receive some inputs on this issue...
Thank´s, Gary
Re: Database problems after installati on of service pack 1 ACADE2012. ..Help!
- Highlight
- Email to a Friend
Do you get any error messages when trying to retag the second time?
What does AutoCAD Electrical say on the command line?
Are you sure that the tags aren't set to "fixed"?
THL
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
- Highlight
- Email to a Friend
Hi Rhesusminus and thanks for helping out!
I dont see any abnormalities in the command line, I have however noticed that doing a project wide update or retag the tags are only updated if I check the %S value for update. My tagformat settings are set to %A%F%S%N
If I change my section value (%A) in the drawings properties the tags will not update accordingly unless I check the %S in the project wide update utility.
Thanks again, Gary
- Highlight
- Email to a Friend
Just tried reproduce the problem in a demo project here without luck.
Could you mail me your project, so that I can try to recreate the problem?
THL
THL
- Highlight
- Email to a Friend
Hi again,
herewith the project...
For your information, I tried also to make a copy of the project to see if the problem existed also in the copied project which it also did. Again, thank´s for looking into this.
Regards, Gary
- Highlight
- Email to a Friend
The project-wide retag did what it was supposed to, so I guess the problem is specific to your computer.
I'm running AcadE 2012 SP1 on Windows 7 x64.
So, what's next.... Uninstall/Reinstall?
I wouldn't waste any more time on this until you've done a complete un/re-install.
Also... Include the SP1 before working with any projects.
THL
THL
- Highlight
- Email to a Friend
Hi Rhesusminus and thank´s for the advice.
What about REPAIR...? I have seen some posts that mention this as an option prior to unistall/install of the software. Are you familiar with this option and how it´s done?
If I have to uninstall/reinstall the software... will I have to make some pre-arrangements or backup of certain data before going ahead with this? Do I use the windows, "Add or Remove Programs" to unistall Autocad 2012 or some other utility ?
Sorry for the bunch of questions and thank´s again for the support.
Regards, Gary
- Highlight
- Email to a Friend
THL
- Highlight
- Email to a Friend
Ok, but what about my question about uninstall and reinstall...is there a tool for this or do I use windows "add remove programs" to uninstall and then go ahead with a normal install of the software?
Thank´s
Gary
- Highlight
- Email to a Friend
Sorry.
Yes, add remove programs.
THL
THL
