• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Customized Symbols - Wires not breaking when symbol inserted
    201 Views, 6 Replies
    10-01-2012 07:50 AM
    I have customized my own block symbols and am trying to insert the symbols into a ladder, however the wires are not breaking. I have inserted my wire connections into the customised symbol. Can some please advise why the wires are not breaking.
    Thanks & regards.
    Please use plain text.
    Active Contributor
    Re: Customized Symbols - Wires not breaking when symbol inserted
    10-01-2012 09:33 AM in reply to: STEVENAR
    Is it possible to attach the symbol for us? And how are you trying to insert it into the drawing?
    *Expert Elite*
    10-01-2012 12:07 PM in reply to: STEVENAR
    Be sure your wire connections are inline with one another.  The Symbol Builder has an audit function that will flsg such errors.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    Active Contributor
    stefan.stamate
    10-02-2012 06:45 AM in reply to: dougmcalexander
    Be sure also that the attributes X1TERM01(right side), X2TERM01(top side), X4TERM01(left side) and X8TERM01(bottom side) are used in the right place.
    Valued Contributor
    10-02-2012 07:15 AM in reply to: dougmcalexander
    That worked. However I am now trying to insert a custom symbol with 6 wire connections 3 on the RHS and 3 on the LHS and again the wires are not automatically breaking. Is this possible?
    Thanks for your help.
    Active Contributor
    stefan.stamate
    10-02-2012 07:43 AM in reply to: STEVENAR
    Be sure that you use different terminal numbers, see the picture below (this is the generic box with 4 terminals)
    Valued Contributor
    10-02-2012 07:56 AM in reply to: stefan.stamate
    Does the spacing in the ladder need to correspond with the spacing between the wire connections? Also can a component like this be inserted into multi-wires which have been inserted separately and not as a ladder?
    Thanks again.
