• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Distinguished Contributor
    Customer request
    57 Views, 1 Replies
    08-10-2004 11:30 AM
    I have a customer that is requesting a "special" way of numbering for the to-from signals.
    He is requesting that the top number be the sheet number (01,02,03 etc) which should be easy.
    But he wants the lower number to be only the last 2 digits of the rung number. A signal ref. to rung 172 will only report number 72. (see attachment)
    Is this possible??
    Chad
    Please use plain text.
    Valued Contributor
    Re: Customer request
    08-10-2004 02:47 PM in reply to: fdna49
    That's the way I used to do it at my previous company in plain AutoCAD and in a competitor's application. We used hexes as a 'line ref symbol' with the sheet number above the line number. In AE, I think you can config to use the hex references, and then modify the particular symbols used to remove the hex if the hex is undesired. That should give you the configuration you are wanting, sheet number centered above line numbers.
    - Jay
    P.S. Duh... after looking at the sample drawing, I see you are wanting to use the hex references. When you create a signal reference, the dialog box will give you the option of selecting from several styles. One of the styles looks exactly like you have in your sample drawing.
