OK. Several things to check....
1. Check what layers they are being changed to by ACADE upon insertion, then check the layer is turned on.
2. Check the text size. they may be visible but set to a small text size.
3. Have you selected a catalog entry or filled in the CAT and MANF positions in the component edit dialog.
4. If you made the changes to the block file, did you update the block afterwards. Use the Swap/Update tool to do so if you haven't.
To double check the attribute is actually turned on when the block is inserted, right click the block and select attributes.
Now select List/Edit. Now find the CAT and MANF attributes and look for a * on the left of the attribute name. If this * is missing the attribute is still turned off. Click on the name toggle the attribute visibility on/off.
Note that most users of electrical would leave the CAT and MANF hidden to reduce drawing clutter. Under projects, there is a report function which will allow you to do reports on various things about the project. One of these is the BOM (Bill Of Materials). This particular set of reports pulls the CAT and MANF at aminimum and makes a list for ordering or inclusion on a dwg. I've attached an example of one. This is a tallied purchase list but other setups are available, including one that lists the component tags along with the part numbers.
Regards Brad
Brad Coleman, Electrical Draftsman
