• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Distinguished Contributor
    Custom Panduit
    275 Views, 3 Replies
    04-15-2009 01:40 PM
    How can I make a custom panduit? OOB only has 3 different kinds. I want to make the new "PanelMax" double panduit with integrated din rail to save on panel space.
    Ken
    Please use plain text.
    Re: Custom Panduit
    04-15-2009 02:28 PM in reply to: kenaslan
    You can add/edit DIN rail and wireways using Excel. Look for a file called wddinrl.xls in the Catalogs folder.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    Re: Custom Panduit
    01-07-2010 10:33 AM in reply to: kenaslan
    I have a additional question about this file. I pretty much understand the "DIN_RAIL" tab; but could someone explain what the other tabs used for?
    They are the ones named after Part Numbers and have 4 columns with the following labels: "SLOTQTY", "ORG_LIST", "ORG_LIST", and "ORG_LIST"
    Thanks.
    *Pat Murnen \(Autodesk\)
    Re: Custom Panduit
    01-07-2010 12:49 PM in reply to: kenaslan
    I believe this tells the function where to show the
    mounting holes or standoffs. Since you can insert the din rail at any length up
    to the maximum piece length defined, there can be a different number of slots.
    So say the din rail length requires 13 slots. The function looks in the first
    column and finds 13. Then it uses the rest of the columns to insert the mounting
    holes/standoffs at the slot numbers in each column. So looking at worksheet for
    199-DR1 it would put a mounting hole at slots 2, 7, and 12. If the din rail
    needs more than 3 ORG_LIST columns you can add more.
    Hope this helps,
    Pat Murnen
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    "ORG_LIST"
    Thanks.
