• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    *Expert Elite*
    Accepted Solution
    Copy Footprint problem
    180 Views, 5 Replies
    09-17-2012 12:17 PM
    I have seen this happen on and off over the years and it reared its ugly head again.
    I insert a footprint no problem, but when I use "copy component" the new footprint appears to have a new insertion point that shoots the part several inches above and to the right of where I wanted to insert it.
    If I check the basepoint, it is set to 0,0.
    It seems to happen most often with older drawings that I am adding footprints to. If I start with a fresh drawing and copy the parts to it, the problem goes away.
    Has anyone else experienced something like this?
    Bob Hanrahan
    Ace User since 1998
    Please use plain text.
    Employee
    Re: Copy Footprint problem
    09-19-2012 08:56 AM in reply to: testsubject
    Bob,
    is it possible that the drawing had a previous instance of a footprint with an incorrect base point? Once a block is inserted on a drawing then it becomes the one always used on that drawing unless all instances are erased and the drawing is purged. You can also use the Swap Block to update all instances of a block. This essentially erases all instances of a block, purges the drawing, insert the block getting the latest, and puts all the attribute values back as they were.
    Pat Murnen
    Principal Content Developer
    Information Modeling and Platform Products Group
    Autodesk, Inc.
    *Expert Elite*
    09-19-2012 10:13 AM in reply to: murnenp
    That's the thing Pat. It happens everytime I try to use Swap Block in the same drawing.The updated part ends up in a completely different place on the drawing. Then if I move it back and try swap block again, it move it again.
    I always place the component on 0,0 in the base drawing and made sure that is where my basepoint is set to.
    It is very strange.
    Bob Hanrahan
    Ace User since 1998
    Employee
    09-19-2012 10:39 AM in reply to: testsubject
    Bob, can you post the drawing, the library symbol and the steps to reproduce? Or email it to me directly at pat.murnen@autodesk.com. Maybe if I look try it myself I might discover the cause.
    Pat Murnen
    Autodesk, Inc.
    *Expert Elite*
    09-19-2012 01:29 PM in reply to: murnenp
    Sent
    Bob Hanrahan
    Ace User since 1998
    Employee
    09-20-2012 06:51 AM in reply to: testsubject
    Bob,
    per our emails - this was a result of a different UCS being used with an origin different than 0,0. Once the UCS was set to World then the Swap Block worked as expected.
    Pat
    Pat Murnen
    Autodesk, Inc.
