• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Accepted Solution
    Converted to «o» to «x» in the dialog box « Panel Components...»
    114 Views, 3 Replies
    12-06-2012 12:23 AM
    I start the Insert Component (Panel List) command.
    In the dialog box « Panel Components...» in the left column displays the «x» and «o».
    What command can be converted to «o» to «x»?
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    Re: Converted to «o» to «x» in the dialog box « Panel Components...»
    12-06-2012 02:39 AM in reply to: galashkina
    If you press the HELP-button in this dialog, the help-file says:
    "An "x" displays in left-hand column for any listed panel component tag that already has its schematic component inserted on the drawing and there is an exact match on catalog and manufacturer values between the two. An "o" displays if the tags match but there is mismatch on catalog and manufacturer values between the two."
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
    12-06-2012 02:50 AM in reply to: rhesusminus
    Can somehow update the database of the project to the "o" was transformed into an "x"?
    rhesusminus
    12-06-2012 03:30 AM in reply to: galashkina
    I don't belive you can do this amutomatically.
    You'll have to go to the components marked "o", and make sure that the Manufacturer/Catalog data matches on both schematic and panel components.
    THL
