AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Converted to «o» to «x» in the dialog box « Panel Components ...»
- Highlight
- Email to a Friend
I start the Insert Component (Panel List) command.
In the dialog box « Panel Components...» in the left column displays the «x» and «o».
What command can be converted to «o» to «x»?
Re: Converted to «o» to «x» in the dialog box « Panel Components ...»
- Highlight
- Email to a Friend
If you press the HELP-button in this dialog, the help-file says:
"An "x" displays in left-hand column for any listed panel component tag that already has its schematic component inserted on the drawing and there is an exact match on catalog and manufacturer values between the two. An "o" displays if the tags match but there is mismatch on catalog and manufacturer values between the two."
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
- Highlight
- Email to a Friend
Can somehow update the database of the project to the "o" was transformed into an "x"?
- Highlight
- Email to a Friend
I don't belive you can do this amutomatically.
You'll have to go to the components marked "o", and make sure that the Manufacturer/Catalog data matches on both schematic and panel components.
THL
