• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Convert .stp to .dwg help.
    18803 Views, 2 Replies
    05-18-2010 12:25 PM
    Does AutoCAD Electrical (2011 or any) have a way to convert Solidworks .stp files to .dwg?
    If not, is there a free file converter that can do this conversion?
    No luck with DWG TrueView or Design Review or Inventor View 2011 or FBX Converter.
    Lots of Manufacturers of Industrial Electrical components are using SolidWorks and posting drawings of there products for engineers to download in .stp file format. It would be a smart idea for AutoDesk to add this conversion feature to ACADE. I really don't want to have to go to SolidWorks just to get the conversion.
    Ronald Michaud
    Electrical Engineer
    Darly Custom Technology Inc.
    www.darlytech.com
    Via Lite V3 thru ACADE 2011
    Please use plain text.
    Valued Contributor
    Re: Convert .stp to .dwg help.
    05-19-2010 07:42 AM in reply to: RMichaud
    Well it looks like I have found the perfect tool.
    http://labs.autodesk.com/technologies/fusion/
    Simple to do, open the .stp file then save as......
    Ron
    Ronald Michaud
    Electrical Engineer
    www.darlytech.com
    Active Member
    09-21-2012 11:33 AM in reply to: RMichaud
    Inventor Fusion 2013 worked like a champ as described above.  The only thing to note is that when I did a "save as" to .dwg, it saved it in a 2013 .dwg format (and why wouldn't it?); so I opened up the model in MEP 2013 and exported it back to 2010 for use in our legacy drawings - no issues.
    Thanks for the hint!
