AutoCAD Electrical
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Carl Smith
Conduit
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
119 Views, 8 Replies
08-06-2004 07:09 AM
In the Insert/Edit conduit/wireway label dialog box, there is a section that
allows you to select the conduit size. The help mentions that ACADE can also
calculate the % full for a particular conduit size based on the wires that
are selected to fill the conduit. I am having trouble understanding how this
works, can someone provide us with a little more information please?
cds
*Pat Murnen \(Autodesk\)
Re: Conduit
Options
- Highlight
- Email to a Friend
08-26-2004 04:12 PM in reply to:
*Carl Smith
There are 2 support files that affect how this works. There is the .WDW file
and the .WW1 file. I've copied some info from the online Help that should
explain how these work together.
The .WDW file contains the wire information. You may have a different file
for each project. Simply create a projname.wdw file and put in the same
directory as your project file (.WDP). If you want to use the same file for
all projects, then create or modify the DEFAULT.WDW file in the USER folder
(use the Settings button on the Project dialog box to find the full path).
This file is a simple text file and can be edited with any text editor such
as WordPad. There should be a separate line in the file for each AutoCAD
Electrical wire layer. The line has three fields, each field separated by a
semi-colon. The first field is the actual wire layer name used on the
drawing. The second field is the wire layer description. This description is
used in the AutoCAD Electrical Wire Color/Gauge Label feature. The third
field is the wire size. (Note this third field is probably not in the file
supplied with AcadE)
For example, you have a wire layer called 14_RED_THHN. When using a wire
color/gauge label you wish the label to read #14AWG RED for this layer. The
wire itself has a wire diameter of 0.0087. The line in the .WDW file would
read:
14_RED_THHN;#14AWG RED;0.0087
The .WW1 file contains the conduit information. You may have a different
file for each project. Simply create a projname.ww1 file and put in the same
all projects, then create or modify the DEFAULT.WW1 file in the USER folder
as WordPad. There should be a separate line in the file for each conduit.
Each line has two fields. The first field is the conduit size that will be
shown in the Conduit Marker dialog. The second field is the conduit size,
i.e. the inner diameter of the conduit, so AutoCAD Electrical can determine
how full the conduit is once you add up all the wire diameter sizes from the
wires (pulled from the .WDW file). For example, you have a 1" conduit with
an inner diameter of 0.5. The line in the .WW1 file would read
1";0.5
So using the wire size and the conduit size the calculation is made and
displayed. If there is no .WW1 file or is if the wire sizes are not in the
file the calculations are not made.
If this still does not work, let me know and I will investigate further.
Pat Murnen (Autodesk)
"Carl Smith" wrote in message
news:4113911f$1_1@newsprd01...
that
also
this
> cds
*dns
Re: Conduit
Options
- Highlight
- Email to a Friend
09-15-2004 04:33 PM in reply to:
*Carl Smith
I have 2 questions/issues on the conduit sizing/report.
1. I can't get it to work right. I don't know if it's my input values or
the math in cad itself. I just used as an example the wire size from a
cutsheet and nominal conduit values off the NEC code. My default.wdw and
.ww1 file located in ..\Autodesk\AutoCAD Electrical
2005\R16.1\enu\Support\User are as follows:
default.wdw
12_XHHW;1.52
default.ww1
1";1.063
i'm getting a fill of 214% for 15 wires. Thinking that it must be
cross-sectional area, and not diameter, i used .01815 for the #12 wire data
which gives me a fil of 26% which sounds more reasonable. But then for my
conduit report, the wire diameter is listed as .01815.
2. Is there a way to updated the project to recheck the .wdw and .ww1 file
like the rebuild feature. Just to run the example above and change wire
diameter in the .wdw file, AE doesn't seem to recognize the change when i
re-run he conduit marker feature. I only affects it when i close out of AE
and re-open.
"Pat Murnen (Autodesk)" wrote in message
news:412e6e6e$1_1@newsprd01...
file
for
folder
such
a
is
The
> read:
same
for
folder
such
determine
the
> 1";0.5
> that
> also
that
> this
> > cds
Re: Conduit
Options
- Highlight
- Email to a Friend
09-16-2004 06:51 AM in reply to:
*Carl Smith
I am going to hold off answering question #1 until I investigate a little
further. As far as question #2, you can reset this by selecting Projects ->
Extras -> Set Global Variable Value. Enter GBL_wd_wdwinfo and set value to
nil. This should force a reread of the .wdw file.
"dns" wrote in message news:4148d166$1_2@newsprd01...
> default.wdw
> 12_XHHW;1.52
> default.ww1
> 1";1.063
data
file
AE
> and re-open.
> file
should
file
> for
> folder
path).
> such
by
> a
description
> is
file
> The
would
> > read:
> same
> for
> folder
path).
> such
conduit.
be
size,
> determine
> the
with
> > 1";0.5
the
section
> > that
can
> > also
> that
how
> > this
> > > cds
*dns
Re: Conduit
Options
- Highlight
- Email to a Friend
09-20-2004 08:52 AM in reply to:
*Carl Smith
any answers on Question #1? for the wire size, i mis-typed it in the post.
it should be .0152, which is the value in the .wdw file.
news:41499a50_2@newsprd01...
Projects ->
or
and
> > default.wdw
> > 12_XHHW;1.52
> > default.ww1
> > 1";1.063
> data
my
> file
i
> AE
> > and re-open.
message
.WDW
> > file
> should
> file
same
file
> > for
> > folder
> path).
> > such
AutoCAD
> by
> > a
> description
> > is
third
> file
wire
layer.
> > The
> would
> > > read:
different
the
> > same
file
> > for
> > folder
> path).
> > such
> conduit.
will
> be
> size,
> > determine
from
> > the
> with
> > > 1";0.5
and
> the
further.
> section
> > > that
> can
> > > also
wires
> > that
> how
> > > this
> > > > cds
Re: Conduit
Options
- Highlight
- Email to a Friend
09-20-2004 11:37 AM in reply to:
*Carl Smith
I looked back to see the math used. It looks like it does a simple addition
of all the diameter values for the wires included in the conduit. Then it
takes that sum and divides it by the conduit diameter for each size and then
multiplies by 100 to get percentage.
conduitsize = pulled from .ww1 file for example 1";1.063
wiresize = pulled from .wdw file
wsum = sum of wiresizes for each wire in conduit
fill = ((/ wsum conduitsize) 100.0)
Any feedback you have on this is appreciated.
"dns" wrote in message news:414efcc5$1_1@newsprd01...
> post.
> Projects ->
>> to
> or
> and
>> > default.wdw
>> > 12_XHHW;1.52
>> > default.ww1
>> > 1";1.063
>> data
> my
>> file
>> > wire
> i
>> > of
>> AE
>> > and re-open.
> message
> .WDW
>> > file
>> should
>> file
> same
> file
>> > for
>> > folder
>> path).
>> > > editor
>> > such
> AutoCAD
>> > > separated
>> by
>> > a
>> description
>> > is
> third
>> file
> wire
> layer.
>> > The
>> would
>> > > read:
> different
> the
>> > same
> file
>> > for
>> > folder
>> path).
>> > > editor
>> > such
>> conduit.
> will
>> be
>> size,
>> > determine
> from
>> > the
>> with
>> > > 1";0.5
> and
>> > > in
>> the
> further.
>> section
>> > > that
>> can
>> > > also
> wires
>> > that
>> how
>> > > this
>> > > > please?
>> > > > cds
*dns
Re: Conduit
Options
- Highlight
- Email to a Friend
09-21-2004 10:44 AM in reply to:
*Carl Smith
That explains why I get 214% fill for 15 #12 wires (d=.152") in 1" conduit
(d=1.063"). What this math is calculating is only the linear diameter of
all wires, and determining if it fits in the diameter of the conduit, which
is definately wrong. What it should calculate is the sum of the
cross-sectional area of all wires to determine if it fits in the
cross-sectional area of the conduit. With the math currently used, only 7
#12 wires would fit in a 1" conduit (100%). Just tabulating off a Code book
shows that 19 #12 wires can be run in a 1" conduit, and that is maintaining
a 40% fill (Required by code). Hope this helps. let me know if it's
possible for me to modify the math in AE itself somehow.
thanks.
news:414f2360$1_1@newsprd01...
addition
then
> > post.
message
little
> > Projects ->
> >> to
values
> > or
a
> > and
> >> > default.wdw
> >> > 12_XHHW;1.52
> >> > default.ww1
> >> > 1";1.063
wire
> >> data
for
> > my
.ww1
> >> file
> >> > wire
when
> > i
> >> > of
> >> AE
> >> > and re-open.
> > message
> > .WDW
> >> > file
> >> should
different
> >> file
> > same
> > file
> >> > for
USER
> >> > folder
> >> path).
> >> > > editor
> >> > such
> > AutoCAD
> >> > > separated
> >> by
> >> > a
the
> >> description
> >> > is
> > third
the
> >> file
> > wire
> > layer.
> >> > The
file
> >> would
> >> > > read:
> > different
> > the
> >> > same
> > file
> >> > for
USER
> >> > folder
> >> path).
> >> > > editor
> >> > such
> >> conduit.
> > will
> >> be
> >> size,
> >> > determine
> > from
> >> > the
conduit
> >> with
> >> > > 1";0.5
> > and
> >> > > in
> >> the
> > further.
> >> section
> >> > > that
ACADE
> >> can
> >> > > also
> > wires
> >> > that
understanding
> >> how
> >> > > this
> >> > > > please?
> >> > > > cds
Re: Conduit
Options
- Highlight
- Email to a Friend
09-21-2004 11:44 AM in reply to:
*Carl Smith
I'm afraid there isn't any way for you to modify the math used. I will log
this into the system so the issue is raised.
Thanks for the feedback.
"dns" wrote in message news:41506898_2@newsprd01...
> which
> book
> maintaining
> thanks.
> addition
> then
>> > post.
> message
> little
>> > Projects ->
>> >> value
>> >> to
> values
>> > or
>> >> > from
> a
>> >> > default.wdw
>> > and
>> >> > default.wdw
>> >> > 12_XHHW;1.52
>> >> > default.ww1
>> >> > 1";1.063
> wire
>> >> data
> for
>> > my
> .ww1
>> >> file
>> >> > wire
> when
>> > i
>> >> > out
>> >> > of
>> >> AE
>> >> > and re-open.
>> > message
>> > .WDW
>> >> > file
>> >> should
> different
>> >> file
>> > same
>> > file
>> >> > for
> USER
>> >> > folder
>> >> > > full
>> >> path).
>> >> > > editor
>> >> > such
>> > AutoCAD
>> >> > > separated
>> >> by
>> >> > a
> the
>> >> description
>> >> > is
>> > third
> the
>> >> file
>> >> > > a
>> > wire
>> > layer.
>> >> > The
> file
>> >> would
>> >> > > read:
>> > different
>> >> > > in
>> > the
>> >> > same
>> > file
>> >> > for
> USER
>> >> > folder
>> >> > > full
>> >> path).
>> >> > > editor
>> >> > such
>> >> conduit.
>> > will
>> >> be
>> >> > > conduit
>> >> size,
>> >> > determine
>> >> > > sizes
>> > from
>> >> > the
> conduit
>> >> with
>> >> > > 1";0.5
>> >> > > made
>> > and
>> >> > > not
>> >> > > in
>> >> the
>> > further.
>> >> section
>> >> > > that
> ACADE
>> >> can
>> >> > > also
>> > wires
>> >> > that
> understanding
>> >> how
>> >> > > this
>> >> > > > please?
>> >> > > > cds
Re: Conduit
Options
- Highlight
- Email to a Friend
01-30-2005 08:03 AM in reply to:
*Carl Smith
No guarantees on this but as a workaround, try the attached lisp file and
dialog definition file to calculate the fill percentage of a conduit marker.
Feel free to modify this routine in any way. To use it you will need to load
the lisp file in AutoCAD and the dialog definition file, .dcl, will need to
be in an AutoCAD search path or you could enter the path in the lisp file.
Then at the command line enter calc_fill. This will look for your wire
information in the .WDW file and the conduit information in the .WW1 file.
If that information is found you will be asked to pick a conduit marker.
Once selected it will read the wire information off the conduit marker. It
will calculate the cross-sectional area for each wire based on its wire
diameter (pulled from .WDW file). It will add up these cross-sectional areas
and then divide it by the cross-sectional area of each conduit. And finally
multiply by 100 to get the %. Finally a small dialog will display with the %
for each conduit size.
So this calculation expects the wire diameter in the .WDW file and the
conduit's inner cross-sectional area in the .WW1. Feel free to modify this
calculation in any way you see fit. This is supplied as a starting point but
it should allow you to keep the wire diamter in the .WDW file so it is
correct in your reports..
Hope this helps,
Pat Murnen
> which
> book
> maintaining
> thanks.
> addition
> then
>> > post.
> message
> little
>> > Projects ->
>> >> value
>> >> to
> values
>> > or
>> >> > from
> a
>> >> > default.wdw
>> > and
>> >> > default.wdw
>> >> > 12_XHHW;1.52
>> >> > default.ww1
>> >> > 1";1.063
> wire
>> >> data
> for
>> > my
> .ww1
>> >> file
>> >> > wire
> when
>> > i
>> >> > out
>> >> > of
>> >> AE
>> >> > and re-open.
>> > message
>> > .WDW
>> >> > file
>> >> should
> different
>> >> file
>> > same
>> > file
>> >> > for
> USER
>> >> > folder
>> >> > > full
>> >> path).
>> >> > > editor
>> >> > such
>> > AutoCAD
>> >> > > separated
>> >> by
>> >> > a
> the
>> >> description
>> >> > is
>> > third
> the
>> >> file
>> >> > > a
>> > wire
>> > layer.
>> >> > The
> file
>> >> would
>> >> > > read:
>> > different
>> >> > > in
>> > the
>> >> > same
>> > file
>> >> > for
> USER
>> >> > folder
>> >> > > full
>> >> path).
>> >> > > editor
>> >> > such
>> >> conduit.
>> > will
>> >> be
>> >> > > conduit
>> >> size,
>> >> > determine
>> >> > > sizes
>> > from
>> >> > the
> conduit
>> >> with
>> >> > > 1";0.5
>> >> > > made
>> > and
>> >> > > not
>> >> > > in
>> >> the
>> > further.
>> >> section
>> >> > > that
> ACADE
>> >> can
>> >> > > also
>> > wires
>> >> > that
> understanding
>> >> how
>> >> > > this
>> >> > > > please?
>> >> > > > cds
