AutoCAD Electrical
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Jack Feyes
Component made with BlackBoxBu ilder
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
49 Views, 1 Replies
12-16-2003 09:15 AM
I made a part with the black box builder, it has three terminals on its left
side, three terminals on the right and eight terminals across the bottom.
The insertion point of the block is the upper left terminals (x1term01)
attribute insertion point. The problem I am having is that when I insert
this block with the component picker and try to drop it on three phase wires
the block rotates 90 degrees. Any ideas?
*Jared Bunch \(Autodesk, Inc\)
Re: Component made with BlackBoxBu ilder
Options
- Highlight
- Email to a Friend
12-17-2003 02:22 PM in reply to:
*Jack Feyes
Jack
This sounds like the block probably has a name starting with "V" for
vertical. You will want to rename the block so it begins with an "H" for
horizontal and it should insert fine. When using BBB (Black Box Builder),
the program will look to see what orientation has the most wire connection
points and use that in the naming convention. As you can see, if it not
intended to be a vertical block and the name begins with a "V", it can cause
some headaches when attempting to insert it. In your case, you had more
connection points for vertical wires, so it treated as though it was going
to be a vertical block. Give this a try and I think you will be fine.
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"Jack Feyes" wrote in message
news:3fdf3dbf_2@statler...
left
wires
