• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    *Expert Elite*
    Accepted Solution
    Changing the Terminal TAG-ID
    180 Views, 2 Replies
    01-24-2013 01:32 PM
    I know I am just missing something simple, but  how do you change a group of terminals Tag-ID on a schematic without using Find/Replace/Project Rebuild? I know I could change each one individually using edit terminal. Looking to change a bunch.
    I am using ACE 2013.
    Bob Hanrahan
    Ace User since 1998
    Please use plain text.
    Distinguished Mentor
    Re: Changing the Terminal TAG-ID
    01-24-2013 02:19 PM in reply to: testsubject
    Go into the Terminal Strip editer and select the terminal strip that has the terminals you wish to change.
    Select ALL the terminals you wish to change the ID on and then right click on one of the selected terminals.
    From the list, choose terminals then REASSIGN.
    Now just change the Strip ID as required.
    Note that this is from the 2008 version, so it should still be available in the 2013 release, but you may have to hunt a bit for the commands
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    *Expert Elite*
    01-25-2013 06:23 AM in reply to: Icemanau
    Thanks Brad!
    I knew it had to be something simple but I was just not seeing it.
    Bob Hanrahan
    Ace User since 1998
